The devmap_dup(9E) entry point is called when a device mapping is duplicated, for example, by a user process that calls fork(2). The driver is expected to generate new driver private data for the new mapping.
The syntax fordevmap_dup() is as follows:
int xxdevmap_dup(devmap_cookie_t handle, void *devprivate,
devmap_cookie_t new-handle, void **new-devprivate);
where:
Mapping handle of the mapping being duplicated.
Mapping handle of the mapping that was duplicated.
Pointer to the driver private data associated with the mapping being duplicated.
Should be set to point to the new driver private data for the new mapping.
Mappings that have been created with devmap_dup() by default have their mapping translations invalidated. Invalid mapping translations force a call to the devmap_access(9E) entry point the first time the mapping is accessed.
The following example shows a typical devmap_dup() routine.
static int
devmap_cookie_t new_handle, void **new_devprivate)
struct xxctx *ctxp = devprivate;
struct xxstate *xsp = ctxp->xsp;
struct xxctx *newctx;
/* Create a new context for the duplicated mapping */
newctx = kmem_alloc(sizeof (struct xxctx), KM_SLEEP);
newctx->xsp = xsp;
newctx->handle = new_handle;
newctx->offset = ctxp->offset;
newctx->flags = ctxp->flags;
newctx->len = ctxp->len;
mutex_enter(&xsp->ctx_lock);
if (ctxp->flags & MAP_PRIVATE) {
newctx->context = kmem_alloc(XXCTX_SIZE, KM_SLEEP);
bcopy(ctxp->context, newctx->context, XXCTX_SIZE);
} else {
newctx->context = xsp->ctx_shared;
mutex_exit(&xsp->ctx_lock);
*new_devprivate = newctx;
return(0);
