Some device drivers might need to allocate kernel memory that is made accessible to user programs through mmap(2). One example is setting up shared memory for communication between two applications. Another example is sharing memory between a driver and an application.
When exporting kernel memory to user applications, follow these steps:
Use ddi_umem_alloc(9F) to allocate kernel memory.
Use devmap_umem_setup(9F) to export the memory.
Use ddi_umem_free(9F) to free the memory when the memory is no longer needed.
Use ddi_umem_alloc(9F) to allocate kernel memory that is exported to applications. ddi_umem_alloc() uses the following syntax:
void *ddi_umem_alloc(size_t size, int flag, ddi_umem_cookie_t *cookiep);
where:
Number of bytes to allocate.
Used to determine the sleep conditions and the memory type.
Pointer to a kernel memory cookie.
ddi_umem_alloc(9F) allocates page-aligned kernel memory. ddi_umem_alloc() returns a pointer to the allocated memory. Initially, the memory is filled with zeroes. The number of bytes that are allocated is a multiple of the system page size, which is rounded up from the size parameter. The allocated memory can be used in the kernel. This memory can be exported to applications as well. cookiep is a pointer to the kernel memory cookie that describes the kernel memory being allocated. cookiep is used in devmap_umem_setup(9F) when the driver exports the kernel memory to a user application.
The flag argument indicates whether ddi_umem_alloc(9F) blocks or returns immediately, and whether the allocated kernel memory is pageable. The values for the flag argument as follows:
Driver does not need to wait for memory to become available. Return NULL if memory is not available.
Driver can wait indefinitely for memory to become available.
Driver allows memory to be paged out. If not set, the memory is locked down.
The ddi_umem_lock() function can perform device-locked-memory checks. The function checks against the limit value that is specified in project.max-locked-memory. If the current project locked-memory usage is below the limit, the project's locked-memory byte count is increased. After the limit check, the memory is locked. The ddi_umem_unlock() function unlocks the memory, and the project's locked-memory byte count is decremented.
The accounting method that is used is an imprecise full price model. For example, two callers of umem_lockmemory() within the same project with overlapping memory regions are charged twice.
For information about the project.max-locked-memory and zone.max-locked_memory resource controls on Solaris systems with zones installed, see Solaris Containers: Resource Management and Solaris Zones Developer’s Guide and see resource_controls(5).
The following example shows how to allocate kernel memory for application access. The driver exports one page of kernel memory, which is used by multiple applications as a shared memory area. The memory is allocated in segmap(9E) when an application maps the shared page the first time. An additional page is allocated if the driver has to support multiple application data models. For example, a 64-bit driver might export memory both to 64-bit applications and to 32-bit applications. 64-bit applications share the first page, and 32-bit applications share the second page.
static int
xxsegmap(dev_t dev, off_t off, struct as *asp, caddr_t *addrp, off_t len,
unsigned int prot, unsigned int maxprot, unsigned int flags,
cred_t *credp)
int error;
minor_t instance = getminor(dev);
struct xxstate *xsp = ddi_get_soft_state(statep, instance);
size_t mem_size;
/* 64-bit driver supports 64-bit and 32-bit applications */
switch (ddi_mmap_get_model()) {
case DDI_MODEL_LP64:
mem_size = ptob(2);
break;
case DDI_MODEL_ILP32:
mem_size = ptob(1);
break;
mutex_enter(&xsp->mu);
if (xsp->umem == NULL) {
/* allocate the shared area as kernel pageable memory */
xsp->umem = ddi_umem_alloc(mem_size,
DDI_UMEM_SLEEP | DDI_UMEM_PAGEABLE, &xsp->ucookie);
mutex_exit(&xsp->mu);
/* Set up the user mapping */
error = devmap_setup(dev, (offset_t)off, asp, addrp, len,
prot, maxprot, flags, credp);
return (error);
Use devmap_umem_setup(9F) to export kernel memory to user applications. devmap_umem_setup() must be called from the driver's devmap(9E) entry point. The syntax for devmap_umem_setup() is as follows:
int devmap_umem_setup(devmap_cookie_t handle, dev_info_t *dip,
struct devmap_callback_ctl *callbackops, ddi_umem_cookie_t cookie,
offset_t koff, size_t len, uint_t maxprot, uint_t flags,
ddi_device_acc_attr_t *accattrp);
where:
Opaque structure used to describe the mapping.
Pointer to the device's dev_info structure.
Pointer to a devmap_callback_ctl(9S) structure.
Kernel memory cookie returned by ddi_umem_alloc(9F).
Offset into the kernel memory specified by cookie.
Length in bytes that is exported.
Specifies the maximum protection possible for the exported mapping.
Must be set to DEVMAP_DEFAULTS.
Pointer to a ddi_device_acc_attr(9S) structure.
handle is a device-mapping handle that the system uses to identify the mapping. handle is passed in by the devmap(9E) entry point. dip is a pointer to the device's dev_info structure. callbackops enables the driver to be notified of user events on the mapping. Most drivers set callbackops to NULL when kernel memory is exported.
koff and len specify a range within the kernel memory allocated by ddi_umem_alloc(9F). This range is made accessible to the user's application mapping at the offset that is passed in by the devmap(9E) entry point. Usually, the driver passes the devmap(9E) offset directly to devmap_umem_setup(9F). The return address of mmap(2) then maps to the kernel address returned by ddi_umem_alloc(9F). koff and len must be page-aligned.
maxprot enables the driver to specify different protections for different regions within the exported kernel memory. For example, one region might not allow write access by only setting PROT_READ and PROT_USER.
The following example shows how to export kernel memory to an application. The driver first checks whether the requested mapping falls within the allocated kernel memory region. If a 64-bit driver receives a mapping request from a 32-bit application, the request is redirected to the second page of the kernel memory area. This redirection ensures that only applications compiled to the same data model share the same page.
static int
xxdevmap(dev_t dev, devmap_cookie_t handle, offset_t off, size_t len,
size_t *maplen, uint_t model)
struct xxstate *xsp;
int error;
/* round up len to a multiple of a page size */
len = ptob(btopr(len));
/* check if the requested range is ok */
if (off + len > ptob(1))
return (ENXIO);
xsp = ddi_get_soft_state(statep, getminor(dev));
if (xsp == NULL)
return (ENXIO);
if (ddi_model_convert_from(model) == DDI_MODEL_ILP32)
/* request from 32-bit application. Skip first page */
off += ptob(1);
/* export the memory to the application */
error = devmap_umem_setup(handle, xsp->dip, NULL, xsp->ucookie,
off, len, PROT_ALL, DEVMAP_DEFAULTS, NULL);
*maplen = len;
return (error);
When the driver is unloaded, the memory that was allocated by ddi_umem_alloc(9F) must be freed by calling ddi_umem_free(9F).
void ddi_umem_free(ddi_umem_cookie_t cookie);
cookie is the kernel memory cookie returned by ddi_umem_alloc(9F).
