Writing Device Drivers
GLDv2 Declarations and Data Structures
This section describes the gld_mac_info(9S) and gld_stats structures.
gld_mac_info Structure
The GLDv2 MAC information (gld_mac_info) structure is the main data interface that links the device-specific driver with GLDv2. This structure contains data required by GLDv2 and a pointer to an optional additional driver-specific information structure.
Allocate the gld_mac_info structure using gld_mac_alloc(). Deallocate the structure using gld_mac_free(). Drivers must not make any assumptions about the length of this structure, which might vary in different releases of the Solaris OS, GLDv2, or both. Structure members private to GLDv2, not documented here, should neither be set nor be read by the device-specific driver.
The gld_mac_info(9S) structure contains the following fields.
caddr_t              gldm_private;              /* Driver private data */
int                  (*gldm_reset)();           /* Reset device */
int                  (*gldm_start)();           /* Start device */
int                  (*gldm_stop)();            /* Stop device */
int                  (*gldm_set_mac_addr)();    /* Set device phys addr */
int                  (*gldm_set_multicast)();   /* Set/delete multicast addr */
int                  (*gldm_set_promiscuous)(); /* Set/reset promiscuous mode */
int                  (*gldm_send)();            /* Transmit routine */
uint_t               (*gldm_intr)();            /* Interrupt handler */
int                  (*gldm_get_stats)();       /* Get device statistics */
int                  (*gldm_ioctl)();           /* Driver-specific ioctls */
char                 *gldm_ident;               /* Driver identity string */
uint32_t             gldm_type;                 /* Device type */
uint32_t             gldm_minpkt;               /* Minimum packet size */
                                                /* accepted by driver */
uint32_t             gldm_maxpkt;               /* Maximum packet size */
uint32_t             gldm_addrlen;              /* Physical address length */
int32_t              gldm_saplen;               /* SAP length for DL_INFO_ACK */
unsigned char        *gldm_broadcast_addr;      /* Physical broadcast addr */
unsigned char        *gldm_vendor_addr;         /* Factory MAC address */
t_uscalar_t          gldm_ppa;                  /* Physical Point of */
                                                /* Attachment (PPA) number */
dev_info_t           *gldm_devinfo;             /* Pointer to device's */
                                                /* dev_info node */
ddi_iblock_cookie_t  gldm_cookie;               /* Device's interrupt */
                                                /* block cookie */
The gldm_private structure member is visible to the device driver. gldm_private is also private to the device-specific driver. gldm_private is not used or modified by GLDv2. Conventionally, gldm_private is used as a pointer to private data, pointing to a per-instance data structure that is both defined and allocated by the driver.
The following group of structure members must be set by the driver before calling gld_register(), and should not thereafter be modified by the driver. Because gld_register() might use or cache the values of structure members, changes made by the driver after calling gld_register() might cause unpredictable results. For more information on these structures, see the gld(9E) man page.
gldm_reset
Pointer to driver entry point.
gldm_start
gldm_stop
gldm_set_mac_addr
gldm_set_multicast
gldm_send
gldm_intr
gldm_get_stats
gldm_ioctl
Pointer to driver entry point. This pointer is allowed to be null.
gldm_ident
Pointer to a string that contains a short description of the device. This pointer is used to identify the device in system messages.
gldm_type
Type of device the driver handles. GLDv2 currently supports the following values:
  • DL_ETHER (ISO 8802-3 (IEEE 802.3) and Ethernet Bus)
  • DL_TPR (IEEE 802.5 Token Passing Ring)
  • DL_FDDI (ISO 9314-2 Fibre Distributed Data Interface)
This structure member must be correctly set for GLDv2 to function properly.
gldm_minpkt
Minimum Service Data Unit size: the minimum packet size, not including the MAC header, that the device can transmit. This size is allowed to be zero if the device-specific driver handles any required padding.
gldm_maxpkt
Maximum Service Data Unit size: the maximum size of packet, not including the MAC header, that can be transmitted by the device. For Ethernet, this number is 1500.
gldm_addrlen
The length in bytes of physical addresses handled by the device. For Ethernet, Token Ring, and FDDI, the value of this structure member should be 6.
gldm_saplen
The length in bytes of the SAP address used by the driver. For GLDv2-based drivers, the length should always be set to -2. A length of -2 indicates that 2-byte SAP values are supported and that the SAP appears after the physical address in a DLSAP address. See Appendix A.2, “Message DL_INFO_ACK,” in the DLPI specification for more details.
gldm_broadcast_addr
Pointer to an array of bytes of length gldm_addrlen containing the broadcast address to be used for transmit. The driver must provide space to hold the broadcast address, fill the space with the appropriate value, and set gldm_broadcast_addr to point to the address. For Ethernet, Token Ring, and FDDI, the broadcast address is normally 0xFF-FF-FF-FF-FF-FF.
gldm_vendor_addr
Pointer to an array of bytes of length gldm_addrlen that contains the vendor-provided network physical address of the device. The driver must provide space to hold the address, fill the space with information from the device, and set gldm_vendor_addr to point to the address.
gldm_ppa
PPA number for this instance of the device. The PPA number should always be set to the instance number that is returned from ddi_get_instance(9F).
gldm_devinfo
Pointer to the dev_info node for this device.
gldm_cookie
Interrupt block cookie returned by one of the following routines:
This cookie must correspond to the device's receive-interrupt, from which gld_recv() is called.
gld_stats Structure
After calling gldm_get_stats(), a GLDv2-based driver uses the (gld_stats) structure to communicate statistics and state information to GLDv2. See the gld(9E) and gld(7D) man pages. The members of this structure, having been filled in by the GLDv2-based driver, are used when GLDv2 reports the statistics. In the tables below, the name of the statistics variable reported by GLDv2 is noted in the comments. See the gld(7D) man page for a more detailed description of the meaning of each statistic.
Drivers must not make any assumptions about the length of this structure. The structure length might vary in different releases of the Solaris OS, GLDv2, or both. Structure members private to GLDv2, which are not documented here, should not be set or be read by the device-specific driver.
The following structure members are defined for all media types:
uint64_t    glds_speed;                   /* ifspeed */
uint32_t    glds_media;                   /* media */
uint32_t    glds_intr;                    /* intr */
uint32_t    glds_norcvbuf;                /* norcvbuf */
uint32_t    glds_errrcv;                  /* ierrors */
uint32_t    glds_errxmt;                  /* oerrors */
uint32_t    glds_missed;                  /* missed */
uint32_t    glds_underflow;               /* uflo */
uint32_t    glds_overflow;                /* oflo */
The following structure members are defined for media type DL_ETHER:
uint32_t    glds_frame;                   /* align_errors */
uint32_t    glds_crc;                     /* fcs_errors */
uint32_t    glds_duplex;                  /* duplex */
uint32_t    glds_nocarrier;               /* carrier_errors */
uint32_t    glds_collisions;              /* collisions */
uint32_t    glds_excoll;                  /* ex_collisions */
uint32_t    glds_xmtlatecoll;             /* tx_late_collisions */
uint32_t    glds_defer;                   /* defer_xmts */
uint32_t    glds_dot3_first_coll;         /* first_collisions */
uint32_t    glds_dot3_multi_coll;         /* multi_collisions */
uint32_t    glds_dot3_sqe_error;          /* sqe_errors */
uint32_t    glds_dot3_mac_xmt_error;      /* macxmt_errors */
uint32_t    glds_dot3_mac_rcv_error;      /* macrcv_errors */
uint32_t    glds_dot3_frame_too_long;     /* toolong_errors */
uint32_t    glds_short;                   /* runt_errors */
The following structure members are defined for media type DL_TPR:
uint32_t    glds_dot5_line_error          /* line_errors */
uint32_t    glds_dot5_burst_error         /* burst_errors */
uint32_t    glds_dot5_signal_loss         /* signal_losses */
uint32_t    glds_dot5_ace_error           /* ace_errors */
uint32_t    glds_dot5_internal_error      /* internal_errors */
uint32_t    glds_dot5_lost_frame_error    /* lost_frame_errors */
uint32_t    glds_dot5_frame_copied_error  /* frame_copied_errors */
uint32_t    glds_dot5_token_error         /* token_errors */
uint32_t    glds_dot5_freq_error          /* freq_errors */
The following structure members are defined for media type DL_FDDI:
uint32_t    glds_fddi_mac_error;          /* mac_errors */
uint32_t    glds_fddi_mac_lost;           /* mac_lost_errors */
uint32_t    glds_fddi_mac_token;          /* mac_tokens */
uint32_t    glds_fddi_mac_tvx_expired;    /* mac_tvx_expired */
uint32_t    glds_fddi_mac_late;           /* mac_late */
uint32_t    glds_fddi_mac_ring_op;        /* mac_ring_ops */
Most of the above statistics variables are counters that denote the number of times that the particular event was observed. The following statistics do not represent the number of times:
glds_speed
Estimate of the interface's current bandwidth in bits per second. This object should contain the nominal bandwidth for those interfaces that do not vary in bandwidth or where an accurate estimate cannot be made.
glds_media
Type of media (wiring) or connector used by the hardware. The following media names are supported:
  • GLDM_AUI
  • GLDM_BNC
  • GLDM_TP
  • GLDM_10BT
  • GLDM_100BT
  • GLDM_100BTX
  • GLDM_100BT4
  • GLDM_RING4
  • GLDM_RING16
  • GLDM_FIBER
  • GLDM_PHYMII
  • GLDM_UNKNOWN
glds_duplex
Current duplex state of the interface. Supported values are GLD_DUPLEX_HALF and GLD_DUPLEX_FULL. GLD_DUPLEX_UNKNOWN is also allowed.
