int prefix_set_multicast(gld_mac_info_t *macinfo,
unsigned char *multicastaddr, int multiflag);
gldm_set_multicast() enables and disables device-level reception of specific multicast addresses. If the third argument multiflag is set to GLD_MULTI_ENABLE, then gldm_set_multicast() sets the interface to receive packets with the multicast address. gldm_set_multicast() uses the multicast address that is pointed to by the second argument. If multiflag is set to GLD_MULTI_DISABLE, the driver is allowed to disable reception of the specified multicast address.
This function is called whenever GLDv2 wants to enable or disable reception of a multicast, group, or functional address. GLDv2 makes no assumptions about how the device does multicast support and calls this function to enable or disable a specific multicast address. Some devices might use a hash algorithm and a bitmask to enable collections of multicast addresses. This procedure is allowed, and GLDv2 filters out any superfluous packets. If disabling an address could result in disabling more than one address at the device level, the device driver should keep any necessary information. This approach avoids disabling an address that GLDv2 has enabled but not disabled.
gldm_set_multicast() is not called to enable a particular multicast address that is already enabled. Similarly, gldm_set_multicast() is not called to disable an address that is not currently enabled. GLDv2 keeps track of multiple requests for the same multicast address. GLDv2 only calls the driver's entry point when the first request to enable, or the last request to disable, a particular multicast address is made. If sufficient resources are currently not available to carry out the request, the function should return GLD_NORESOURCES. The function should return GLD_NOTSUPPORTED if the requested function is not supported.
