Data-path entry points are comprised of the following components:
Callbacks exported by the driver and invoked by the GLDv3 framework for sending packets.
GLDv3 framework entry points called by the driver for transmit flow control and for receiving packets.
The GLDv3 framework uses the transmit entry point, mc_tx(9E), to pass a chain of message blocks to the driver. Provide a pointer to the mc_tx() entry point in your mac_callbacks structure. See GLDv3 MAC Registration Data Structures for more information about the mac_callbacks structure.
mblk_t *
xx_m_tx(void *arg, mblk_t *mp)
xx_t *xxp = arg;
mblk_t *nmp;
mutex_enter(&xxp->xx_xmtlock);
if (xxp->xx_flags & XX_SUSPENDED) {
while ((nmp = mp) != NULL) {
xxp->xx_carrier_errors++;
mp = mp->b_next;
freemsg(nmp);
mutex_exit(&xxp->xx_xmtlock);
return (NULL);
while (mp != NULL) {
nmp = mp->b_next;
mp->b_next = NULL;
if (!xx_send(xxp, mp)) {
mp->b_next = nmp;
break;
mp = nmp;
return (mp);
The following sections discuss topics related to transmitting data to the hardware.
If the driver cannot send the packets because of insufficient hardware resources, the driver returns the sub-chain of packets that could not be sent. When more descriptors become available at a later time, the driver must invoke mac_tx_update(9F) to notify the framework.
If the driver specified hardware checksum support (see Hardware Checksum Offload), then the driver must do the following tasks:
Use mac_hcksum_get(9F) to check every packet for hardware checksum metadata.
Program the hardware to perform the required checksum calculation.
If the driver specified LSO capabilities (see Large Segment (or Send) Offload), then the driver must use mac_lso_get(9F) to query whether LSO must be performed on the packet.
When the administrator configures VLANs, the MAC layer inserts the needed VLAN headers on the outbound packets before they are passed to the driver through the mc_tx() entry point.
Call the mac_rx(9F) function in your driver's interrupt handler to pass a chain of one or more packets up the stack to the MAC layer. Avoid holding mutex or other locks during the call to mac_rx(). In particular, do not hold locks that could be taken by a transmit thread during a call to mac_rx(). See mc_unicst(9E) for information about the packets that must be sent up to the MAC layer.
The following sections discuss topics related to sending data to the MAC layer.
If the driver specified hardware checksum support (see Hardware Checksum Offload), then the driver must use the mac_hcksum_set(9F) function to associate hardware checksumming metadata with the packet.
VLAN packets must be passed with their tags to the MAC layer. Do not strip the VLAN headers from the packets.
