Device drivers maintain a set of statistics for the device instances they manage. The MAC layer queries these statistics through the mc_getstat(9E) entry point of the driver.
int mc_getstat(void *driver_handle, uint_t stat, uint64_t *stat_value);
The GLDv3 framework uses stat to specify the statistic being queried. The driver uses stat_value to return the value of the statistic specified by stat. If the value of the statistic is returned, mc_getstat() must return 0. If the stat statistic is not supported by the driver, mc_getstat() must return ENOTSUP.
The GLDv3 statistics that are supported are the union of generic MAC statistics and Ethernet-specific statistics. See the mc_getstat(9E) man page for a complete list of supported statistics.
int
xx_m_getstat(void *arg, uint_t stat, uint64_t *val)
xx_t *xxp = arg;
mutex_enter(&xxp->xx_xmtlock);
if ((xxp->xx_flags & (XX_RUNNING|XX_SUSPENDED)) == XX_RUNNING)
xx_reclaim(xxp);
mutex_exit(&xxp->xx_xmtlock);
switch (stat) {
case MAC_STAT_MULTIRCV:
*val = xxp->xx_multircv;
break;
case ETHER_STAT_MACRCV_ERRORS:
*val = xxp->xx_macrcv_errors;
break;
default:
return (ENOTSUP);
return (0);
