In the following example, the high-level mutex (xsp->high_mu) is used only to protect data shared between the high-level interrupt handler and the soft interrupt handler. The protected data includes a queue used by both the high-level interrupt handler and the low-level handler, and a flag that indicates that the low-level handler is running. A separate low-level mutex (xsp->low_mu) protects the rest of the driver from the soft interrupt handler.
static int
mydevattach(dev_info_t *dip, ddi_attach_cmd_t cmd)
struct mydevstate *xsp;
ret = ddi_intr_get_supported_types(dip, &type);
if ((ret != DDI_SUCCESS) || (!(type & DDI_INTR_TYPE_FIXED))) {
cmn_err(CE_WARN, "ddi_intr_get_supported_types() failed");
return (DDI_FAILURE);
ret = ddi_intr_get_nintrs(dip, DDI_INTR_TYPE_FIXED, &count);
* Fixed interrupts can only have one interrupt. Check to make
* sure that number of supported interrupts and number of
* available interrupts are both equal to 1.
if ((ret != DDI_SUCCESS) || (count != 1)) {
cmn_err(CE_WARN, "No fixed interrupts found");
xsp->xs_htable = kmem_zalloc(count * sizeof (ddi_intr_handle_t),
KM_SLEEP);
ret = ddi_intr_alloc(dip, xsp->xs_htable, DDI_INTR_TYPE_FIXED, 0,
count, &actual, 0);
if ((ret != DDI_SUCCESS) || (actual != 1)) {
cmn_err(CE_WARN, "ddi_intr_alloc failed 0x%x", ret");
kmem_free(xsp->xs_htable, sizeof (ddi_intr_handle_t));
ret = ddi_intr_get_pri(xsp->xs_htable[0], &intr_pri);
if (ret != DDI_SUCCESS) {
cmn_err(CE_WARN, "ddi_intr_get_pri failed 0x%x", ret");
(void) ddi_intr_free(xsp->xs_htable[0]);
if (intr_pri >= ddi_intr_get_hilevel_pri()) {
mutex_init(&xsp->high_mu, NULL, MUTEX_DRIVER,
DDI_INTR_PRI(intr_pri));
ret = ddi_intr_add_handler(xsp->xs_htable[0],
mydevhigh_intr, (caddr_t)xsp, NULL);
cmn_err(CE_WARN, "ddi_intr_add_handler failed 0x%x", ret");
mutex_destroy(&xsp>xs_int_mutex);
/* add soft interrupt */
if (ddi_intr_add_softint(xsp->xs_dip, &xsp->xs_softint_hdl,
DDI_INTR_SOFTPRI_MAX, xs_soft_intr, (caddr_t)xsp) !=
DDI_SUCCESS) {
cmn_err(CE_WARN, "add soft interrupt failed");
mutex_destroy(&xsp->high_mu);
(void) ddi_intr_remove_handler(xsp->xs_htable[0]);
xsp->low_soft_pri = DDI_INTR_SOFTPRI_MAX;
mutex_init(&xsp->low_mu, NULL, MUTEX_DRIVER,
DDI_INTR_PRI(xsp->low_soft_pri));
} else {
* regular interrupt registration continues from here
* do not use a soft interrupt
return (DDI_SUCCESS);
The high-level interrupt routine services the device and queues the data. The high-level routine triggers a software interrupt if the low-level routine is not running, as the following example demonstrates.
static uint_t
mydevhigh_intr(caddr_t arg1, caddr_t arg2)
struct mydevstate *xsp = (struct mydevstate *)arg1;
uint8_t status;
volatile uint8_t temp;
int need_softint;
mutex_enter(&xsp->high_mu);
/* read status */
status = ddi_get8(xsp->data_access_handle, &xsp->regp->csr);
if (!(status & INTERRUPTING)) {
mutex_exit(&xsp->high_mu);
return (DDI_INTR_UNCLAIMED); /* dev not interrupting */
ddi_put8(xsp->data_access_handle,&xsp->regp->csr,
CLEAR_INTERRUPT | ENABLE_INTERRUPTS);
/* flush store buffers */
temp = ddi_get8(xsp->data_access_handle, &xsp->regp->csr);
/* read data from device, queue data for low-level interrupt handler */
if (xsp->softint_running)
need_softint = 0;
else {
xsp->softint_count++;
need_softint = 1;
/* read-only access to xsp->id, no mutex needed */
if (need_softint) {
ret = ddi_intr_trigger_softint(xsp->xs_softint_hdl, NULL);
if (ret == DDI_EPENDING) {
cmn_err(CE_WARN, "ddi_intr_trigger_softint() soft interrupt "
"already pending for this handler");
} else if (ret != DDI_SUCCESS) {
cmn_err(CE_WARN, "ddi_intr_trigger_softint() failed");
return (DDI_INTR_CLAIMED);
The low-level interrupt routine is started by the high-level interrupt routine, which triggers a software interrupt. The low-level interrupt routine runs until there is nothing left to process, as the following example shows.
static uint_t
mydev_soft_intr(caddr_t arg1, caddr_t arg2)
struct mydevstate *mydevp = (struct mydevstate *)arg1;
mutex_enter(&mydevp->low_mu);
mutex_enter(&mydevp->high_mu);
if (mydevp->softint_count > 1) {
mydevp->softint_count--;
mutex_exit(&mydevp->high_mu);
mutex_exit(&mydevp->low_mu);
if ( /* queue empty */ ) {
mydevp->softint_running = 1;
while (EMBEDDED COMMENT:data on queue) {
ASSERT(mutex_owned(&mydevp->high_mu);
/* Dequeue data from high-level queue. */
/* normal interrupt processing */
mydevp->softint_running = 0;
mydevp->softint_count = 0;
