The syntax for mutex_owned(9F) is as follows:
int mutex_owned(kmutex_t *mp);
A significant portion of driver development involves properly handling multiple threads. Comments should always be used when a mutex is acquired. Comments can be even more useful when an apparently necessary mutex is not acquired. To determine whether a mutex is held by a thread, use mutex_owned() within ASSERT(9F):
void helper(void)
/* this routine should always be called with xsp's mutex held */
ASSERT(mutex_owned(&xsp->mu));
mutex_owned() is only valid within ASSERT() macros. You should use mutex_owned() to control the behavior of a driver.
