Writing Device Drivers
detach() Entry Point
The syntax for detach(9E) is as follows:
int detach(dev_info_t *dip, ddi_detach_cmd_t cmd);
A device with a reg property or a pm-hardware-state property set to needs-suspend-resume must be able to save the hardware state of the device. The framework calls into the driver's detach(9E) entry point to enable the driver to save the state for restoration after the system power returns. To process the DDI_SUSPEND command, detach(9E) must perform the following tasks:
If the driver is unable to suspend the device and save its state to memory, then the driver must return DDI_FAILURE. The framework then aborts the system power management operation.
In some cases, powering down a device involves certain risks. For example, if a tape drive is powered off with a tape inside, the tape can be damaged. In such a case, attach(9E) should do the following:
If both cases are true, the DDI_SUSPEND request should be rejected. Example 12–6 shows an attach(9E) routine using ddi_removing_power(9F) to check whether the DDI_SUSPEND command causes problems.
Dump requests must be honored. The framework uses the dump(9E) entry point to write out the state file that contains the contents of memory. See the dump(9E) man page for the restrictions that are imposed on the device driver when using this entry point.
Calling the detach(9E) entry point of a power-manageable component with the DDI_SUSPEND command should save the state when the device is powered off. The driver should cancel pending timeouts. The driver should also suppress any calls to pm_raise_power(9F) except for dump(9E) requests. When the device is resumed by a call to attach(9E) with a command of DDI_RESUME, timeouts and calls to pm_raise_power() can be resumed. The driver must keep sufficient track of its state to be able to deal appropriately with this possibility. The following example shows a detach(9E) routine with the DDI_SUSPEND command implemented.
Example 12–6 detach(9E) Routine Implementing DDI_SUSPEND
int
xxdetach(dev_info_t *dip, ddi_detach_cmd_t cmd)
    struct xxstate *xsp;
    int instance;
    instance = ddi_get_instance(dip);
    xsp = ddi_get_soft_state(statep, instance);
    switch (cmd) {
    case DDI_DETACH:
    case DDI_SUSPEND:
        * We do not allow DDI_SUSPEND if power will be removed and
        * we have a device that damages tape when power is removed
        * We do support DDI_SUSPEND for Device Reconfiguration.
        if (ddi_removing_power(dip) && xxdamages_tape(dip))
            return (DDI_FAILURE);
        mutex_enter(&xsp->mu);
        xsp->xx_suspended = 1;  /* stop new operations */
        * Sleep waiting for all the commands to be completed
        * If a callback is outstanding which cannot be cancelled
        * then either wait for the callback to complete or fail the
        * suspend request
        * This section is only needed if the driver maintains a
        * running timeout
        if (xsp->xx_timeout_id) {
            timeout_id_t temp_timeout_id = xsp->xx_timeout_id;
            xsp->xx_timeout_id = 0;
            mutex_exit(&xsp->mu);
            untimeout(temp_timeout_id);
        if (!xsp->xx_state_saved) {
            * Save device register contents into
            * xsp->xx_device_state
        return (DDI_SUCCESS);
    default:
