The prop_op(9E) entry point is generally required for reporting device properties or driver properties to the system. If the driver does not need to create or manage its own properties, then the ddi_prop_op(9F) function can be used for this entry point.
ddi_prop_op(9F) can be used as the prop_op(9E) entry point for a device driver when ddi_prop_op() is defined in the driver's cb_ops(9S) structure. ddi_prop_op() enables a leaf device to search for and obtain property values from the device's property list.
If the driver has to maintain a property whose value changes frequently, you should define a driver-specific prop_op() routine within the cb_ops structure instead of calling ddi_prop_op(). This technique avoids the inefficiency of using ddi_prop_update() repeatedly. The driver should then maintain a copy of the property value either within its soft-state structure or in a driver variable.
The prop_op(9E) entry point reports the values of specific driver properties and device properties to the system. In many cases, the ddi_prop_op(9F) routine can be used as the driver's prop_op() entry point in the cb_ops(9S) structure. ddi_prop_op() performs all of the required processing. ddi_prop_op() is sufficient for drivers that do not require special processing when handling device property requests.
However, sometimes the driver must provide a prop_op() entry point. For example, if a driver maintains a property whose value changes frequently, updating the property with ddi_prop_update(9F) for each change is not efficient. Instead, the driver should maintain a shadow copy of the property in the instance's soft state. The driver would then update the shadow copy when the value changes without using any of the ddi_prop_update() routines. The prop_op() entry point must intercept requests for this property and use one of the ddi_prop_update() routines to update the value of the property before passing the request to ddi_prop_op() to process the property request.
In the following example, prop_op() intercepts requests for the temperature property. The driver updates a variable in the state structure whenever the property changes. However, the property is updated only when a request is made. The driver then uses ddi_prop_op() to process the property request. If the property request is not specific to a device, the driver does not intercept the request. This situation is indicated when the value of the dev parameter is equal to DDI_DEV_T_ANY, the wildcard device number.
static int
xx_prop_op(dev_t dev, dev_info_t *dip, ddi_prop_op_t prop_op,
int flags, char *name, caddr_t valuep, int *lengthp)
minor_t instance;
struct xxstate *xsp;
if (dev != DDI_DEV_T_ANY) {
return (ddi_prop_op(dev, dip, prop_op, flags, name,
valuep, lengthp));
instance = getminor(dev);
xsp = ddi_get_soft_state(statep, instance);
if (xsp == NULL)
return (DDI_PROP_NOTFOUND);
if (strcmp(name, "temperature") == 0) {
ddi_prop_update_int(dev, dip, name, temperature);
/* other cases */
