Writing Device Drivers
scsi_alloc_consistent_buf() Function
For most I/O requests, the data buffer passed to the driver entry points is not accessed directly by the driver. The buffer is just passed on to scsi_init_pkt(9F). If a driver sends SCSI commands that operate on buffers that the driver itself examines, the buffers should be DMA consistent. The SCSI request sense command is a good example. The scsi_alloc_consistent_buf(9F) routine allocates a buf(9S) structure and a data buffer that is suitable for DMA-consistent operations. The HBA performs any necessary synchronization of the buffer before performing the command completion callback.
Note –
scsi_alloc_consistent_buf(9F) uses scarce system resources. Thus, you should use scsi_alloc_consistent_buf() sparingly.
