The dump(9E) entry point copies a portion of virtual address space directly to the specified device in the case of system failure or checkpoint operation. See the cpr(7) and dump(9E) man pages. The dump(9E) entry point must be capable of performing this operation without the use of interrupts.
The arguments for dump() are as follows:
Device number of the dump device
Kernel virtual address at which to start the dump
First destination block on the device
Number of blocks to dump
static int
xxdump(dev_t dev, caddr_t addr, daddr_t blkno, int nblk)
struct xxstate *xsp;
struct buf *bp;
struct scsi_pkt *pkt;
int rval;
int instance;
instance = getminor(dev);
xsp = ddi_get_soft_state(statep, instance);
if (tgt->suspended) {
(void) pm_raise_power(DEVINFO(tgt), 0, 1);
bp = getrbuf(KM_NOSLEEP);
if (bp == NULL) {
return (EIO);
/* Calculate block number relative to partition. */
bp->b_un.b_addr = addr;
bp->b_edev = dev;
bp->b_bcount = nblk * DEV_BSIZE;
bp->b_flags = B_WRITE | B_BUSY;
bp->b_blkno = blkno;
pkt = scsi_init_pkt(ROUTE(tgt), NULL, bp, CDB_GROUP1,
sizeof (struct scsi_arq_status),
sizeof (struct bst_pkt_private), 0, NULL_FUNC, NULL);
if (pkt == NULL) {
freerbuf(bp);
return (EIO);
(void) scsi_setup_cdb((union scsi_cdb *)pkt->pkt_cdbp,
SCMD_WRITE_G1, blkno, nblk, 0);
* While dumping in polled mode, other cmds might complete
* and these should not be resubmitted. we set the
* dumping flag here which prevents requeueing cmds.
tgt->dumping = 1;
rval = scsi_poll(pkt);
tgt->dumping = 0;
scsi_destroy_pkt(pkt);
freerbuf(bp);
if (rval != DDI_SUCCESS) {
rval = EIO;
return (rval);
