After the probe(9E) routine has verified that the expected device is present, attach(9E) is called. attach() performs these tasks:
Allocates and initializes any per-instance data.
Creates minor device node information.
Restores the hardware state of a device after a suspension of the device or the system. See attach() Entry Point for details.
A SCSI target driver needs to call scsi_probe(9F) again to retrieve the device's inquiry data. The driver must also create a SCSI request sense packet. If the attach is successful, the attach() function should not call scsi_unprobe(9F).
Three routines are used to create the request sense packet: scsi_alloc_consistent_buf(9F), scsi_init_pkt(9F), and scsi_setup_cdb(9F). scsi_alloc_consistent_buf(9F) allocates a buffer that is suitable for consistent DMA. scsi_alloc_consistent_buf() then returns a pointer to a buf(9S) structure. The advantage of a consistent buffer is that no explicit synchronization of the data is required. In other words, the target driver can access the data after the callback. The sd_sense element of the device's scsi_device(9S) structure must be initialized with the address of the sense buffer. scsi_init_pkt(9F) creates and partially initializes a scsi_pkt(9S) structure. scsi_setup_cdb(9F) creates a SCSI command descriptor block, in this case by creating a SCSI request sense command.
Note that a SCSI device is not self-identifying and does not have a reg property. As a result, the driver must set the pm-hardware-state property. Setting pm-hardware-state informs the framework that this device needs to be suspended and then resumed.
The following example shows the SCSI target driver's attach() routine.
static int
xxattach(dev_info_t *dip, ddi_attach_cmd_t cmd)
struct xxstate *xsp;
struct scsi_pkt *rqpkt = NULL;
struct scsi_device *sdp;
struct buf *bp = NULL;
int instance;
instance = ddi_get_instance(dip);
switch (cmd) {
case DDI_ATTACH:
break;
case DDI_RESUME:
/* For information, see the "Directory Memory Access (DMA)" */
/* chapter in this book. */
default:
return (DDI_FAILURE);
* Allocate a state structure and initialize it.
xsp = ddi_get_soft_state(statep, instance);
sdp = (struct scsi_device *)ddi_get_driver_private(dip);
* Cross-link the state and scsi_device(9S) structures.
sdp->sd_private = (caddr_t)xsp;
xsp->sdp = sdp;
* Call scsi_probe(9F) again to get and validate inquiry data.
* Allocate a request sense buffer. The buf(9S) structure
* is set to NULL to tell the routine to allocate a new one.
* The callback function is set to NULL_FUNC to tell the
* routine to return failure immediately if no
* resources are available.
bp = scsi_alloc_consistent_buf(&sdp->sd_address, NULL,
SENSE_LENGTH, B_READ, NULL_FUNC, NULL);
if (bp == NULL)
goto failed;
* Create a Request Sense scsi_pkt(9S) structure.
rqpkt = scsi_init_pkt(&sdp->sd_address, NULL, bp,
CDB_GROUP0, 1, 0, PKT_CONSISTENT, NULL_FUNC, NULL);
if (rqpkt == NULL)
goto failed;
* scsi_alloc_consistent_buf(9F) returned a buf(9S) structure.
* The actual buffer address is in b_un.b_addr.
sdp->sd_sense = (struct scsi_extended_sense *)bp->b_un.b_addr;
* Create a Group0 CDB for the Request Sense command
if (scsi_setup_cdb((union scsi_cdb *)rqpkt->pkt_cdbp,
SCMD_REQUEST_SENSE, 0, SENSE__LENGTH, 0) == 0)
goto failed;;
* Fill in the rest of the scsi_pkt structure.
* xxcallback() is the private command completion routine.
rqpkt->pkt_comp = xxcallback;
rqpkt->pkt_time = 30; /* 30 second command timeout */
rqpkt->pkt_flags |= FLAG_SENSING;
xsp->rqs = rqpkt;
xsp->rqsbuf = bp;
* Create minor nodes, report device, and do any other initialization. */
* Since the device does not have the 'reg' property,
* cpr will not call its DDI_SUSPEND/DDI_RESUME entries.
* The following code is to tell cpr that this device
* needs to be suspended and resumed.
(void) ddi_prop_update_string(device, dip,
"pm-hardware-state", "needs-suspend-resume");
xsp->open = 0;
return (DDI_SUCCESS);
failed:
if (bp)
scsi_free_consistent_buf(bp);
if (rqpkt)
scsi_destroy_pkt(rqpkt);
sdp->sd_private = (caddr_t)NULL;
sdp->sd_sense = NULL;
scsi_unprobe(sdp);
/* Free any other resources, such as the state structure. */
