Writing Device Drivers
Declarations and Structures
HBA drivers must include the following header files:
#include <sys/scsi/scsi.h>
#include <sys/ddi.h>
#include <sys/sunddi.h>
To inform the system that the module depends on SCSA routines, the driver binary must be generated with the following command. See SCSA HBA Interfaces for more information on SCSA routines.
% ld -r xx.o -o xx -N "misc/scsi"
The code samples are derived from a simplified isp driver for the QLogic Intelligent SCSI Peripheral device. The isp driver supports WIDE SCSI, with up to 15 target devices and 8 logical units (LUNs) per target.
Per-Command Structure
An HBA driver usually needs to define a structure to maintain state for each command submitted by a target driver. The layout of this per-command structure is entirely up to the device driver writer. The layout needs to reflect the capabilities and features of the hardware and the software algorithms that are used in the driver.
The following structure is an example of a per-command structure. The remaining code fragments of this chapter use this structure to illustrate the HBA interfaces.
struct isp_cmd {
     struct isp_request     cmd_isp_request;
     struct isp_response    cmd_isp_response;
     struct scsi_pkt        *cmd_pkt;
     struct isp_cmd         *cmd_forw;
     uint32_t               cmd_dmacount;
     ddi_dma_handle_t       cmd_dmahandle;
     uint_t                 cmd_cookie;
     uint_t                 cmd_ncookies;
     uint_t                 cmd_cookiecnt;
     uint_t                 cmd_nwin;
     uint_t                 cmd_curwin;
     off_t                  cmd_dma_offset;
     uint_t                 cmd_dma_len;
     ddi_dma_cookie_t       cmd_dmacookies[ISP_NDATASEGS];
     u_int                  cmd_flags;
     u_short                cmd_slot;
     u_int                  cmd_cdblen;
     u_int                  cmd_scblen;
