The tran_start(9E) entry point for a SCSI HBA driver is called to transport a SCSI command to the addressed target. The SCSI command is described entirely within the scsi_pkt(9S) structure, which the target driver allocated through the HBA driver's tran_init_pkt(9E) entry point. If the command involves a data transfer, DMA resources must also have been allocated for the scsi_pkt(9S) structure.
The tran_start() entry point is called when a target driver calls scsi_transport(9F).
tran_start() should perform basic error checking along with any initialization that is required by the command. The FLAG_NOINTR flag in the pkt_flags field of the scsi_pkt(9S) structure can affect the behavior of tran_start(). If FLAG_NOINTR is not set, tran_start() must queue the command for execution on the hardware and return immediately. Upon completion of the command, the HBA driver should call the pkt completion routine.
If the FLAG_NOINTR is set, then the HBA driver should not call the pkt completion routine.
The following example demonstrates how to handle the tran_start(9E) entry point. The ISP hardware provides a queue per-target device. For devices that can manage only one active outstanding command, the driver is typically required to manage a per-target queue. The driver then starts up a new command upon completion of the current command in a round-robin fashion.
static int
isp_scsi_start(
struct scsi_address *ap,
struct scsi_pkt *pkt)
struct isp_cmd *sp;
struct isp *isp;
struct isp_request *req;
u_long cur_lbolt;
int xfercount;
int rval = TRAN_ACCEPT;
int i;
sp = (struct isp_cmd *)pkt->pkt_ha_private;
isp = (struct isp *)ap->a_hba_tran->tran_hba_private;
sp->cmd_flags = (sp->cmd_flags & ~CFLAG_TRANFLAG) |
CFLAG_IN_TRANSPORT;
pkt->pkt_reason = CMD_CMPLT;
* set up request in cmd_isp_request area so it is ready to
* go once we have the request mutex
req = &sp->cmd_isp_request;
req->req_header.cq_entry_type = CQ_TYPE_REQUEST;
req->req_header.cq_entry_count = 1;
req->req_header.cq_flags = 0;
req->req_header.cq_seqno = 0;
req->req_reserved = 0;
req->req_token = (opaque_t)sp;
req->req_target = TGT(sp);
req->req_lun_trn = LUN(sp);
req->req_time = pkt->pkt_time;
ISP_SET_PKT_FLAGS(pkt->pkt_flags, req->req_flags);
* Set up data segments for dma transfers.
if (sp->cmd_flags & CFLAG_DMAVALID) {
if (sp->cmd_flags & CFLAG_CMDIOPB) {
(void) ddi_dma_sync(sp->cmd_dmahandle,
sp->cmd_dma_offset, sp->cmd_dma_len,
DDI_DMA_SYNC_FORDEV);
ASSERT(sp->cmd_cookiecnt > 0 &&
sp->cmd_cookiecnt <= ISP_NDATASEGS);
xfercount = 0;
req->req_seg_count = sp->cmd_cookiecnt;
for (i = 0; i < sp->cmd_cookiecnt; i++) {
req->req_dataseg[i].d_count =
sp->cmd_dmacookies[i].dmac_size;
req->req_dataseg[i].d_base =
sp->cmd_dmacookies[i].dmac_address;
xfercount +=
for (; i < ISP_NDATASEGS; i++) {
req->req_dataseg[i].d_count = 0;
req->req_dataseg[i].d_base = 0;
pkt->pkt_resid = xfercount;
if (sp->cmd_flags & CFLAG_DMASEND) {
req->req_flags |= ISP_REQ_FLAG_DATA_WRITE;
} else {
req->req_flags |= ISP_REQ_FLAG_DATA_READ;
} else {
req->req_seg_count = 0;
req->req_dataseg[0].d_count = 0;
* Set up cdb in the request
req->req_cdblen = sp->cmd_cdblen;
bcopy((caddr_t)pkt->pkt_cdbp, (caddr_t)req->req_cdb,
sp->cmd_cdblen);
* Start the cmd. If NO_INTR, must poll for cmd completion.
if ((pkt->pkt_flags & FLAG_NOINTR) == 0) {
mutex_enter(ISP_REQ_MUTEX(isp));
rval = isp_i_start_cmd(isp, sp);
mutex_exit(ISP_REQ_MUTEX(isp));
} else {
rval = isp_i_polled_cmd_start(isp, sp);
return (rval);
