The M_IOCDATA message is generated by the stream head and sent downstream as a response to an M_COPYIN or M_COPYOUT message. The message format is one M_IOCDATA message block followed by zero or more M_DATA blocks. The M_IOCDATA message block contains a copyresp(9S), defined in sys/stream.h.
#if defined(_LP64) struct copyresp { int cp_cmd; /* ioctl command (from ioc_cmd) */ cred_t *cp_cr; /* full credentials (from ioc_cmd) */ uint cp_id; /* ioctl id (from ioc_id) */ uint cp_flag; /* see above */ mblk_t *cp_private; /* private state information */ caddr_t cp_rval; /* status of request: 0 -> success */ /* non-zero -> failure */ }; #else struct copyresp { int cp_cmd; /* ioctl command (from ioc_cmd) */ cred_t *cp_cr; /* full credentials */ uint cp_id; /* ioctl id (from ioc_id) */ caddr_t cp_rval /* status of request: 0 -> success */ /* non-zero -> failure */ size_t cp_pad1; uint cp_pad2; mblk_t *cp_private; /* private state information */ uint cp_flag; /* see above */ int cp_filler[3]; }; #endif /* _LP64 */ |
The first three members of the structure correspond to those of the iocblk(9S) in the M_IOCTL message that allows the same message blocks to be reused for all of the related transparent messages (M_COPYIN, M_COPYOUT, M_IOCACK, M_IOCNAK). The cp_rval field contains the result of the request at the stream head. Zero indicates success and non-zero indicates failure. If failure is indicated, the module should not generate an M_IOCNAK message. It must abort all ioctl(2) processing, clean up its data structures, and return.
The cp_private field is copied from the cq_private field in the associated M_COPYIN or M_COPYOUT message. It is included in the M_IOCDATA message so the message can be self-describing. This is intended to simplify ioctl(2) processing by modules and drivers.
If the message is in response to an M_COPYIN message and success is indicated, the M_IOCDATA block is followed by M_DATA blocks containing the data copied in.
If an M_IOCDATA block is reused, any unused fields defined for the resultant message block should be cleared (particularly in an M_IOCACK or M_IOCNAK).
This message should not be queued by a module or driver unless it processes the data for the ioctl in some way.
