This section describes data types that are used by GSS-API.
OM_uint32
The OM_uint32 is a platform-independent 32-bit unsigned
integer.
The definition of the gss_buffer_desc with
the gss_buffer_t pointer takes the following form:
typedef struct gss_buffer_desc_struct {
size_t length;
void *value;
} gss_buffer_desc, *gss_buffer_t;
The definition of the gss_OID_desc with the gss_OID pointer takes the following form:
typedef struct gss_OID_desc_struct {
OM_uint32 length;
void*elements;
} gss_OID_desc, *gss_OID;
The definition of the gss_OID_set_desc with
the gss_OID_set pointer takes the following form:
typedef struct gss_OID_set_desc_struct {
size_t count;
gss_OID elements;
} gss_OID_set_desc, *gss_OID_set;
The definition of the gss_channel_bindings_struct structure and the gss_channel_bindings_t pointer has the following form:
typedef struct gss_channel_bindings_struct {
OM_uint32 initiator_addrtype;
gss_buffer_desc initiator_address;
OM_uint32 acceptor_addrtype;
gss_buffer_desc acceptor_address;
gss_buffer_desc application_data;
} *gss_channel_bindings_t;
