Oracle Solaris Security for Developers Guide
GSS-API Major Status Code Values
The following tables list the calling errors that are returned by GSS-API. These errors are specific to a particular language-binding, which is C in this case.
Table B–1 GSS-API Calling Errors
Error
Value in Field
Meaning
GSS_S_CALL_INACCESSIBLE_READ
1
An input parameter that is required could not be read
GSS_S_CALL_INACCESSIBLE_WRITE
2
A required output parameter could not be written
GSS_S_CALL_BAD_STRUCTURE
3
A parameter was malformed
The following table lists the GSS-API routine errors, generic errors that are returned by GSS-API functions.
Table B–2 GSS-API Routine Errors
Error
Value in Field
Meaning
GSS_S_BAD_MECH
1
An unsupported mechanism was requested.
GSS_S_BAD_NAME
2
An invalid name was supplied.
GSS_S_BAD_NAMETYPE
3
A supplied name was of an unsupported type.
GSS_S_BAD_BINDINGS
4
Incorrect channel bindings were supplied.
GSS_S_BAD_STATUS
5
An invalid status code was supplied.
GSS_S_BAD_MIC, GSS_S_BAD_SIG
6
A token had an invalid MIC.
GSS_S_NO_CRED
7
The credentials were unavailable, inaccessible, or not supplied.
GSS_S_NO_CONTEXT
8
No context has been established.
GSS_S_DEFECTIVE_TOKEN
9
A token was invalid.
GSS_S_DEFECTIVE_CREDENTIAL
10
A credential was invalid.
GSS_S_CREDENTIALS_EXPIRED
11
The referenced credentials have expired.
GSS_S_CONTEXT_EXPIRED
12
The context has expired.
GSS_S_FAILURE
13
Miscellaneous failure. The underlying mechanism detected an error for which no specific GSS-API status code is defined. The mechanism-specific status code, that is, the minor-status code, provides more details about the error.
GSS_S_BAD_QOP
14
The quality-of-protection that was requested could not be provided.
GSS_S_UNAUTHORIZED
15
The operation is forbidden by local security policy.
GSS_S_UNAVAILABLE
16
The operation or option is unavailable.
GSS_S_DUPLICATE_ELEMENT
17
The requested credential element already exists.
GSS_S_NAME_NOT_MN
18
The provided name was not a mechanism name (MN).
The name GSS_S_COMPLETE, which is a zero value, indicates an absence of any API errors or supplementary information bits.
The following table lists the supplementary information values returned by GSS-API functions.
Table B–3 GSS-API Supplementary Information Codes
Code
Bit Number
Meaning
GSS_S_CONTINUE_NEEDED
0 (LSB)
Returned only by gss_init_sec_context() or gss_accept_sec_context(). The routine must be called again to complete its function.
GSS_S_DUPLICATE_TOKEN
1
The token was a duplicate of an earlier token.
GSS_S_OLD_TOKEN
2
The token's validity period has expired.
GSS_S_UNSEQ_TOKEN
3
A later token has already been processed.
GSS_S_GAP_TOKEN
4
An expected per-message token was not received.
For more on status codes, see GSS-API Status Codes.
