The source code for the server-side program, gss_server, is provided in the following example.
The source code for this example is also available through the Sun download center. See http://www.sun.com/download/products.xml?id=41912db5.
* Copyright 1994 by OpenVision Technologies, Inc.
* Permission to use, copy, modify, distribute, and sell this software
* and its documentation for any purpose is hereby granted without fee,
* provided that the above copyright notice appears in all copies and
* that both that copyright notice and this permission notice appear in
* supporting documentation, and that the name of OpenVision not be used
* in advertising or publicity pertaining to distribution of the software
* without specific, written prior permission. OpenVision makes no
* representations about the suitability of this software for any
* purpose. It is provided "as is" without express or implied warranty.
* OPENVISION DISCLAIMS ALL WARRANTIES WITH REGARD TO THIS SOFTWARE,
* INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS, IN NO
* EVENT SHALL OPENVISION BE LIABLE FOR ANY SPECIAL, INDIRECT OR
* CONSEQUENTIAL DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF
* USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR
* OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR
* PERFORMANCE OF THIS SOFTWARE.
#if !defined(lint) && !defined(__CODECENTER__)
static char *rcsid = \
"$Header: /cvs/krbdev/krb5/src/appl/gss-sample/gss-server.c, \
v 1.21 1998/12/22 \
04:10:08 tytso Exp $";
#endif
#include <stdio.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <sys/time.h>
#include <netinet/in.h>
#include <unistd.h>
#include <stdlib.h>
#include <ctype.h>
#include <gssapi/gssapi.h>
#include <gssapi/gssapi_ext.h>
#include <gss-misc.h>
#include <string.h>
void usage()
fprintf(stderr, "Usage: gss-server [-port port] [-verbose]\n");
fprintf(stderr, " [-inetd] [-logfile file] [service_name]\n");
exit(1);
FILE *log;
int verbose = 0;
* Function: server_acquire_creds
* Purpose: imports a service name and acquires credentials for it
* Arguments:
* service_name (r) the ASCII service name
* server_creds (w) the GSS-API service credentials
* Returns: 0 on success, -1 on failure
* Effects:
* The service name is imported with gss_import_name, and service
* credentials are acquired with gss_acquire_cred. If either operation
* fails, an error message is displayed and -1 is returned; otherwise,
* 0 is returned.
int server_acquire_creds(service_name, server_creds)
char *service_name;
gss_cred_id_t *server_creds;
gss_buffer_desc name_buf;
gss_name_t server_name;
OM_uint32 maj_stat, min_stat;
name_buf.value = service_name;
name_buf.length = strlen(name_buf.value) + 1;
maj_stat = gss_import_name(&min_stat, &name_buf,
(gss_OID) GSS_C_NT_HOSTBASED_SERVICE, &server_name);
if (maj_stat != GSS_S_COMPLETE) {
display_status("importing name", maj_stat, min_stat);
return -1;
maj_stat = gss_acquire_cred(&min_stat, server_name, 0,
GSS_C_NULL_OID_SET, GSS_C_ACCEPT,
server_creds, NULL, NULL);
display_status("acquiring credentials", maj_stat, min_stat);
return -1;
(void) gss_release_name(&min_stat, &server_name);
return 0;
* Function: server_establish_context
* Purpose: establishes a GSS-API context as a specified service with
* an incoming client, and returns the context handle and associated
* client name
* Arguments:
* s (r) an established TCP connection to the client
* service_creds (r) server credentials, from gss_acquire_cred
* context (w) the established GSS-API context
* client_name (w) the client's ASCII name
* Effects:
* Any valid client request is accepted. If a context is established,
* its handle is returned in context and the client name is returned
* in client_name and 0 is returned. If unsuccessful, an error
* message is displayed and -1 is returned.
int server_establish_context(s, server_creds, context, client_name, \
ret_flags)
int s;
gss_cred_id_t server_creds;
gss_ctx_id_t *context;
gss_buffer_t client_name;
OM_uint32 *ret_flags;
gss_buffer_desc send_tok, recv_tok;
gss_name_t client;
gss_OID doid;
OM_uint32 maj_stat, min_stat, acc_sec_min_stat;
gss_buffer_desc oid_name;
*context = GSS_C_NO_CONTEXT;
do {
if (recv_token(s, &recv_tok) < 0)
return -1;
if (verbose && log) {
fprintf(log, "Received token (size=%d): \n", recv_tok.length);
print_token(&recv_tok);
maj_stat =
gss_accept_sec_context(&acc_sec_min_stat,
context,
server_creds,
&recv_tok,
GSS_C_NO_CHANNEL_BINDINGS,
&client,
&doid,
&send_tok,
ret_flags,
NULL, /* ignore time_rec */
NULL); /* ignore del_cred_handle */
(void) gss_release_buffer(&min_stat, &recv_tok);
if (send_tok.length != 0) {
fprintf(log,
"Sending accept_sec_context token (size=%d):\n",
send_tok.length);
print_token(&send_tok);
if (send_token(s, &send_tok) < 0) {
fprintf(log, "failure sending token\n");
return -1;
(void) gss_release_buffer(&min_stat, &send_tok);
if (maj_stat!=GSS_S_COMPLETE && maj_stat!=GSS_S_CONTINUE_NEEDED) {
display_status("accepting context", maj_stat,
acc_sec_min_stat);
if (*context == GSS_C_NO_CONTEXT)
gss_delete_sec_context(&min_stat, context,
GSS_C_NO_BUFFER);
return -1;
if (maj_stat == GSS_S_CONTINUE_NEEDED)
fprintf(log, "continue needed...\n");
else
fprintf(log, "\n");
fflush(log);
} while (maj_stat == GSS_S_CONTINUE_NEEDED);
/* display the flags */
display_ctx_flags(*ret_flags);
maj_stat = gss_oid_to_str(&min_stat, doid, &oid_name);
display_status("converting oid->string", maj_stat, min_stat);
return -1;
fprintf(log, "Accepted connection using mechanism OID %.*s.\n",
(int) oid_name.length, (char *) oid_name.value);
(void) gss_release_buffer(&min_stat, &oid_name);
maj_stat = gss_display_name(&min_stat, client, client_name, &doid);
display_status("displaying name", maj_stat, min_stat);
return -1;
maj_stat = gss_release_name(&min_stat, &client);
display_status("releasing name", maj_stat, min_stat);
return -1;
return 0;
* Function: create_socket
* Purpose: Opens a listening TCP socket.
* Arguments:
* port (r) the port number on which to listen
* Returns: the listening socket file descriptor, or -1 on failure
* Effects:
* A listening socket on the specified port is created and returned.
* On error, an error message is displayed and -1 is returned.
int create_socket(port)
u_short port;
struct sockaddr_in saddr;
int s;
int on = 1;
saddr.sin_family = AF_INET;
saddr.sin_port = htons(port);
saddr.sin_addr.s_addr = INADDR_ANY;
if ((s = socket(AF_INET, SOCK_STREAM, 0)) < 0) {
perror("creating socket");
return -1;
/* Let the socket be reused right away */
(void) setsockopt(s, SOL_SOCKET, SO_REUSEADDR, (char *)&on,
sizeof(on));
if (bind(s, (struct sockaddr *) &saddr, sizeof(saddr)) < 0) {
perror("binding socket");
(void) close(s);
return -1;
if (listen(s, 5) < 0) {
perror("listening on socket");
(void) close(s);
return -1;
return s;
static float timeval_subtract(tv1, tv2)
struct timeval *tv1, *tv2;
return ((tv1->tv_sec - tv2->tv_sec) +
((float) (tv1->tv_usec - tv2->tv_usec)) / 1000000);
* Yes, yes, this isn't the best place for doing this test.
* DO NOT REMOVE THIS UNTIL A BETTER TEST HAS BEEN WRITTEN, THOUGH.
* -TYT
int test_import_export_context(context)
OM_uint32 min_stat, maj_stat;
gss_buffer_desc context_token, copied_token;
struct timeval tm1, tm2;
* Attempt to save and then restore the context.
gettimeofday(&tm1, (struct timezone *)0);
maj_stat = gss_export_sec_context(&min_stat, context, \
&context_token);
display_status("exporting context", maj_stat, min_stat);
return 1;
gettimeofday(&tm2, (struct timezone *)0);
if (verbose && log)
fprintf(log, "Exported context: %d bytes, %7.4f seconds\n",
context_token.length, timeval_subtract(&tm2, &tm1));
copied_token.length = context_token.length;
copied_token.value = malloc(context_token.length);
if (copied_token.value == 0) {
fprintf(log, "Couldn't allocate memory to copy context \
token.\n");
return 1;
memcpy(copied_token.value, context_token.value, \
copied_token.length);
maj_stat = gss_import_sec_context(&min_stat, &copied_token, \
context);
display_status("importing context", maj_stat, min_stat);
return 1;
free(copied_token.value);
if (verbose && log)
fprintf(log, "Importing context: %7.4f seconds\n",
timeval_subtract(&tm1, &tm2));
(void) gss_release_buffer(&min_stat, &context_token);
return 0;
* Function: sign_server
* Purpose: Performs the "sign" service.
* Arguments:
* s (r) a TCP socket on which a connection has been
* accept()ed
* service_name (r) the ASCII name of the GSS-API service to
* establish a context as
* Returns: -1 on error
* Effects:
* sign_server establishes a context, and performs a single sign request.
* A sign request is a single GSS-API sealed token. The token is
* unsealed and a signature block, produced with gss_sign, is returned
* to the sender. The context is then destroyed and the connection
* closed.
* If any error occurs, -1 is returned.
int sign_server(s, server_creds)
int s;
gss_buffer_desc client_name, xmit_buf, msg_buf;
gss_ctx_id_t context;
int i, conf_state, ret_flags;
char *cp;
/* Establish a context with the client */
if (server_establish_context(s, server_creds, &context,
&client_name, &ret_flags) < 0)
return(-1);
printf("Accepted connection: \"%.*s\"\n",
(int) client_name.length, (char *) client_name.value);
(void) gss_release_buffer(&min_stat, &client_name);
for (i=0; i < 3; i++)
if (test_import_export_context(&context))
return -1;
/* Receive the sealed message token */
if (recv_token(s, &xmit_buf) < 0)
return(-1);
fprintf(log, "Sealed message token:\n");
print_token(&xmit_buf);
maj_stat = gss_unwrap(&min_stat, context, &xmit_buf, &msg_buf,
&conf_state, (gss_qop_t *) NULL);
display_status("unsealing message", maj_stat, min_stat);
return(-1);
} else if (! conf_state) {
fprintf(stderr, "Warning! Message not encrypted.\n");
(void) gss_release_buffer(&min_stat, &xmit_buf);
fprintf(log, "Received message: ");
cp = msg_buf.value;
if ((isprint(cp[0]) || isspace(cp[0])) &&
(isprint(cp[1]) || isspace(cp[1]))) {
fprintf(log, "\"%.*s\"\n", msg_buf.length, msg_buf.value);
} else {
printf("\n");
print_token(&msg_buf);
/* Produce a signature block for the message */
maj_stat = gss_get_mic(&min_stat, context, GSS_C_QOP_DEFAULT,
&msg_buf, &xmit_buf);
display_status("signing message", maj_stat, min_stat);
return(-1);
(void) gss_release_buffer(&min_stat, &msg_buf);
/* Send the signature block to the client */
if (send_token(s, &xmit_buf) < 0)
return(-1);
/* Delete context */
maj_stat = gss_delete_sec_context(&min_stat, &context, NULL);
display_status("deleting context", maj_stat, min_stat);
return(-1);
fflush(log);
return(0);
int
main(argc, argv)
int argc;
char **argv;
char *service_name;
OM_uint32 min_stat;
u_short port = 4444;
int s;
int once = 0;
int do_inetd = 0;
log = stdout;
display_file = stdout;
argc--; argv++;
while (argc) {
if (strcmp(*argv, "-port") == 0) {
argc--; argv++;
if (!argc) usage();
port = atoi(*argv);
} else if (strcmp(*argv, "-verbose") == 0) {
verbose = 1;
} else if (strcmp(*argv, "-once") == 0) {
once = 1;
} else if (strcmp(*argv, "-inetd") == 0) {
do_inetd = 1;
} else if (strcmp(*argv, "-logfile") == 0) {
argc--; argv++;
if (!argc) usage();
log = fopen(*argv, "a");
display_file = log;
if (!log) {
perror(*argv);
exit(1);
} else
break;
argc--; argv++;
if (argc != 1)
usage();
if ((*argv)[0] == '-')
usage();
service_name = *argv;
if (server_acquire_creds(service_name, &server_creds) < 0)
return -1;
if (do_inetd) {
close(1);
close(2);
sign_server(0, server_creds);
close(0);
} else {
int stmp;
if ((stmp = create_socket(port)) >= 0) {
do {
/* Accept a TCP connection */
if ((s = accept(stmp, NULL, 0)) < 0) {
perror("accepting connection");
continue;
/* this return value is not checked, because there's
not really anything to do if it fails */
sign_server(s, server_creds);
close(s);
} while (!once);
close(stmp);
(void) gss_release_cred(&min_stat, &server_creds);
/*NOTREACHED*/
(void) close(s);
return 0;
