Oracle Solaris Modular Debugger Guide
Kernel Memory Caches
This section explains how to find and examine kernel memory caches. You can learn about the various kmem caches on the system by issuing the ::kmastat command.
> ::kmastat
cache                        buf    buf    buf    memory     alloc alloc
name                        size in use  total    in use   succeed  fail
kmem_magazine_1                8     24   1020      8192        24     0
kmem_magazine_3               16    141    510      8192       141     0
kmem_magazine_7               32     96    255      8192        96     0
kmem_alloc_8                   8   3614   3751     90112   9834113     0
kmem_alloc_16                 16   2781   3072     98304   8278603     0
kmem_alloc_24                 24    517    612     24576    680537     0
kmem_alloc_32                 32    398    510     24576    903214     0
kmem_alloc_40                 40    482    584     32768    672089     0
thread_cache                 368    107    126     49152    669881     0
lwp_cache                    576    107    117     73728       182     0
turnstile_cache               36    149    292     16384    670506     0
cred_cache                    96      6     73      8192   2677787     0
If you run ::kmastat you get a feel for what a “normal” system looks like. This will help you to spot excessively large caches on systems that are leaking memory. The results of ::kmastat will vary depending on the system you are running on, how many processes are running, and so forth.
Another way to list the various kmem caches is with the ::kmem_cache command:
> ::kmem_cache
ADDR     NAME                      FLAG  CFLAG  BUFSIZE  BUFTOTL
70036028 kmem_magazine_1           0020 0e0000        8     1020
700362a8 kmem_magazine_3           0020 0e0000       16      510
70036528 kmem_magazine_7           0020 0e0000       32      255
70039428 kmem_alloc_8              020f 000000        8     3751
700396a8 kmem_alloc_16             020f 000000       16     3072
70039928 kmem_alloc_24             020f 000000       24      612
70039ba8 kmem_alloc_32             020f 000000       32      510
7003a028 kmem_alloc_40             020f 000000       40      584
This command is useful because it maps cache names to addresses, and provides the debugging flags for each cache in the FLAG column. It is important to understand that the allocator's selection of debugging features is derived on a per-cache basis from this set of flags. These are set in conjunction with the global kmem_flags variable at cache creation time. Setting kmem_flags while the system is running has no effect on the debugging behavior, except for subsequently created caches (which is rare after boot-up).
Next, walk the list of kmem caches directly using MDB's kmem_cache walker:
> ::walk kmem_cache
70036028
700362a8
70036528
700367a8
This produces a list of pointers that correspond to each kmem cache in the kernel. To find out about a specific cache, apply the kmem_cache macro:
> 0x70039928$<kmem_cache
0x70039928:     lock
0x70039928:     owner/waiters
                0
0x70039930:     flags           freelist        offset
                20f             707c86a0        24
0x7003993c:     global_alloc    global_free     alloc_fail
                523             0               0
0x70039948:     hash_shift      hash_mask       hash_table
                5               1ff             70444858
0x70039954:     nullslab
0x70039954:     cache           base            next
                70039928        0               702d5de0
0x70039960:     prev            head            tail
                707c86a0        0               0
0x7003996c:     refcnt          chunks
                -1              0
0x70039974:     constructor     destructor      reclaim
                0               0               0
0x70039980:     private         arena           cflags
                0               104444f8        0
0x70039994:     bufsize         align           chunksize
                24              8               40
0x700399a0:     slabsize        color           maxcolor
                8192            24              32
0x700399ac:     slab_create     slab_destroy    buftotal
                3               0               612
0x700399b8:     bufmax          rescale         lookup_depth
                612             1               0
0x700399c4:     kstat           next            prev
                702c8608        70039ba8        700396a8
0x700399d0:     name    kmem_alloc_24
0x700399f0:     bufctl_cache    magazine_cache  magazine_size
                70037ba8        700367a8        15
Important fields for debugging include 'bufsize', 'flags' and 'name'. The name of the kmem_cache (in this case “kmem_alloc_24”) indicates its purpose in the system. Bufsize indicates the size of each buffer in this cache; in this case, the cache is used for allocations of size 24 and smaller. 'flags' indicates what debugging features are turned on for this cache. You can find the debugging flags listed in <sys/kmem_impl.h>. In this case 'flags' is 0x20f, which is KMF_AUDIT | KMF_DEADBEEF | KMF_REDZONE | KMF_CONTENTS | KMF_HASH. This document explains each of the debugging features in subsequent sections.
When you are interested in looking at buffers in a particular cache, you can walk the allocated and freed buffers in that cache directly:
> 0x70039928::walk kmem
704ba010
702ba008
704ba038
702ba030
> 0x70039928::walk freemem
70a9ae50
70a9ae28
704bb730
704bb2f8
MDB provides a shortcut to supplying the cache address to the kmem walker: a specific walker is provided for each kmem cache, and its name is the same as the name of the cache. For example:
> ::walk kmem_alloc_24
704ba010
702ba008
704ba038
702ba030
> ::walk thread_cache
70b38080
70aac060
705c4020
70aac1e0
Now you know how to iterate over the kernel memory allocator's internal data structures and examine the most important members of the kmem_cache data structure.
