Oracle Solaris Modular Debugger Guide
STREAMS Walkers
b_cont
Given the address of an mblk_t, iterate over the set of associated message structures by following the b_cont pointer. The b_cont pointer is used to link a given message block to the next associated message block that is the continuation of the same message. The message block is described in more detail in msgb(9S)
b_next
Given the address of an mblk_t, iterate over the set of associated message structures by following the b_next pointer. The b_next pointer is used to link a given message block to the next associated message block on a given queue. The message block is described in more detail in msgb(9S).
qlink
Given the address of a queue_t structure, walk the list of related queues using the q_link pointer. This structure is defined in <sys/stream.h>.
qnext
Given the address of a queue_t structure, walk the list of related queues using the q_next pointer. This structure is defined in <sys/stream.h>.
readq
Given the address of an stdata_t structure, walk the list of read-side queue structures.
writeq
Given the address of an stdata_t structure, walk the list of write-side queue structures.
