Name | Synopsis | Description | Options | Operands | Usage | Examples | Environment Variables | Exit Status | Attributes | See Also | Diagnostics
cut -b list [-n] [file]...
cut -c list [file]...
cut -f list [-d delim] [-s] [file]...
Use the cut utility to cut out columns from a table or fields from each line of a file; in data base parlance, it implements the projection of a relation. The fields as specified by list can be fixed length, that is, character positions as on a punched card (-c option) or the length can vary from line to line and be marked with a field delimiter character like TAB (-f option). cut can be used as a filter.
Either the -b, -c, or -f option must be specified.
Use grep(1) to make horizontal ``cuts'' (by context) through a file, or paste(1) to put files together column-wise (that is, horizontally). To reorder columns in a table, use cut and paste.
The following options are supported:
A comma-separated or blank-character-separated list of integer field numbers (in increasing order), with optional - to indicate ranges (for instance, 1,4,7; 1-3,8; -5,10 (short for 1-5,10); or 3- (short for third through last field)).
The list following -b specifies byte positions (for instance, -b1-72 would pass the first 72 bytes of each line). When -b and -n are used together, list is adjusted so that no multi-byte character is split.
The list following -c specifies character positions (for instance, -c1-72 would pass the first 72 characters of each line).
The character following -d is the field delimiter (-f option only). Default is tab. Space or other characters with special meaning to the shell must be quoted. delim can be a multi-byte character.
The list following -f is a list of fields assumed to be separated in the file by a delimiter character (see -d ); for instance, -f1,7 copies the first and seventh field only. Lines with no field delimiters will be passed through intact (useful for table subheadings), unless -s is specified.
Do not split characters. When -b list and -n are used together, list is adjusted so that no multi-byte character is split.
Suppresses lines with no delimiter characters in case of -f option. Unless specified, lines with no delimiters will be passed through untouched.
The following operands are supported:
A path name of an input file. If no file operands are specified, or if a file operand is -, the standard input will be used.
See largefile(5) for the description of the behavior of cut when encountering files greater than or equal to 2 Gbyte (231 bytes).
A mapping of user IDs to names follows:
example% cut -d: -f1,5 /etc/passwd |
To set name to current login name:
example$ name=`who am i | cut -f1 -d' '` |
See environ(5) for descriptions of the following environment variables that affect the execution of cut: LANG, LC_ALL, LC_CTYPE, LC_MESSAGES, and NLSPATH.
The following exit values are returned:
All input files were output successfully.
An error occurred.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWcsu |
CSI |
Enabled |
Interface Stability |
Standard |
Either file cannot be read or does not exist. If multiple files are present, processing continues.
Missing delim on -d option.
Missing list on -b, -c, or -f option.
