Name | Synopsis | Description | Options | Operands | Usage | Examples | Environment Variables | Exit Status | Attributes | See Also
head [-number | -n number] [filename]...
The head utility copies the first number of lines of each filename to the standard output. If no filename is given, head copies lines from the standard input. The default value of number is 10 lines.
When more than one file is specified, the start of each file will look like:
==> filename <==
Thus, a common way to display a set of short files, identifying each one, is:
example% head -9999 filename1 filename2 ... |
The following options are supported:
The first number lines of each input file will be copied to standard output. The number option-argument must be a positive decimal integer.
The number argument is a positive decimal integer with the same effect as the -n number option.
If no options are specified, head will act as if -n 10had been specified.
The following operand is supported:
A path name of an input file. If no file operands are specified, the standard input will be used.
See largefile(5) for the description of the behavior of head when encountering files greater than or equal to 2 Gbyte ( 231 bytes).
To write the first ten lines of all files (except those with a leading period) in the directory:
example% head * |
See environ(5) for descriptions of the following environment variables that affect the execution of head: LANG, LC_ALL, LC_CTYPE, LC_MESSAGES, and NLSPATH.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWcsu |
CSI |
enabled |
Interface Stability |
Standard |
