Name | Synopsis | Description | Options | Files | Attributes | See Also | Diagnostics
/usr/ccs/bin/sccsdiff [-p] -rsid -rsid [diff-options] s.filename
sccsdiff compares two versions of an SCCS file and displays the differences between the two versions. Any number of SCCS files may be specified. The options specified apply to all named s.files.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWsprot |
diff(1), sccs(1), sccs-delta(1), sccs-get(1), sccs-help(1), sccs-prs(1), sccs-prt(1), what(1), sccsfile(4), attributes(5)
If the two versions are the same.
Use the SCCS help command for explanations of other messages. See sccs-help(1).
