Name | Synopsis | Description | Usage | Examples | Exit Status | Attributes | See Also | Diagnostics
cachefswssize logfile
The cachefswssize command displays the workspace size determined from logfile. This includes the amount of cache space needed for each filesystem that was mounted under the cache, as well as a total.
See largefile(5) for the description of the behavior of cachefswssize when encountering files greater than or equal to 2 Gbyte ( 231 bytes).
example% cachefswssize /var/tmp/samlog
/home/sam |
end size: |
10688k |
high water size: |
10704k |
/foo |
end size: |
128k |
high water size: |
128k |
/usr/dist |
end size: |
1472k |
high water size: |
1472k |
total for cache |
initial size: |
110960k |
end size: |
12288k |
high water size: |
12304k |
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWcsu |
There were problems encountered when the kernel was writing the logfile. The most common problem is running out of disk space.
The logfile is not a valid logfile or was created with a newer version of Solaris than the one where cachefswssize is running.
