Name | Synopsis | Description | Options | Operands | Files | Attributes | See Also | Notes
/usr/sbin/cfgadm [-c configure] [-f]
[-o disable-at-boot | enable-at-boot ] ac#:bank# ...
/usr/sbin/cfgadm [-c unconfigure]
[-o disable-at-bootp | enable-at-boot ] ac#:bank# ...
/usr/sbin/cfgadm [-v]
[-o quick | normal | extended, [max_errors=#] ] -t ac#:bank#...
/usr/sbin/cfgadm -x relocate-test ac#:bank# ...
/usr/sbin/cfgadm [-l] -o disable-at-boot | enable-at-boot ac#:bank# ...
The ac hardware specific library /usr/platform/sun4u/lib/cfgadm/cfgadm_ac.so.1 provides the functionality for configuring and unconfiguring memory banks on E6X00, E5X00, E4X00 and E3X00 systems as part of the Dynamic Reconfiguration of CPU/Memory boards using cfgadm_sysctrl(1M).
Memory banks appear as attachment points in the device tree. For each CPU/Memory board, two attachment points are published, one for each bank on the board: bank0 and bank1. If the bank is unpopulated, the receptacle state is empty. If the bank is populated, the receptacle state is connected. The receptacle state of a memory bank can never be disconnected. The occupant state of a connected memory bank can be configured or unconfigured. If the occupant state is configured, the memory is in use by Solaris, if unconfigured it is not.
Refer to cfgadm(1M) for complete descriptions of the command options.
The following options are supported:
Change the occupant state. The configure argument ensures that the memory is initialized and adds the memory to the Solaris memory pool. The unconfigure argument removes the memory from use by Solaris. When a CPU/Memory board is to be removed from a system, both banks of memory must be unconfigured.
cfgadm refuses the configure operation if the memory on the board is marked disabled-at-boot (see info field), unless either the -f (force) option or the enable at boot flag, (-o enable-at-boot), is given. The configure operation takes a short time proportional to the size of memory that must be initialized.
cfgadm refuses the unconfigure operation if there is not enough uncommitted memory in the system (VM viability error) or if the bank to be unconfigured has memory that can't be removed (non-relocatable pages error). The presence of non-relocatable pages is indicated by the word permanent in the info listing field. Removing memory from use by Solaris may take a significant time due to factors such as system load and how much paging to secondary storage is required. The unconfigure operation can be cancelled at any time and the memory returned to the fully configured state by interrupting the command invocation with a signal. The unconfigure operation self-cancels if no memory can be removed within a timeout period. The default timeout period of 60 seconds can be changed using the -o timeout=# option, with a value of 0 disabling the timeout.
Force option. Use this option to override the block on configuring a memory bank marked as disabled at boot in the non-volatile disabled-memory-list variable. See Platform Notes:Sun Enterprise 6x00/5x00/4x00/3x00 Systems
List option. This option is supported as described in cfgadm(1M).
The type field is always memory.
The info field has the following information for empty banks:
slot# empty |
The slot# indicates the system slot into which the CPU/Memory board is inserted. For example, if this were slot11 the attachment point for use with cfgadm to manipulate the associated board would be sysctrl0:slot11. The info field has the following information for connected banks:
slot# sizeMb|sizeGb [(sizeMb|sizeGb used)] base 0x###
[interleaved #-way] [disabled at boot] [permanent]
The size of the bank is given in Mb or Gb as appropriate. If the memory is less than completely used, the used size is reported. The physical base address is given in hexadecimal. If the memory bank is interleaved with some other bank, the interleave factor is reported. If the memory on the board is disabled at boot using the non-volatile disabled-memory-list variable, this is reported. If the bank has memory that cannot be removed this is reported as permanent.
These options allow the state of the non-volatile disabled-memory-list variable to be modified. These options can be used in conjunction with the issuing of a -c option or with the explicit or implied listing command, -l, if no command is required. Use of -o enable-at-boot with the configure command to override the block on configuring memory on a board in the disabled memory list.
Use with the -t option to specify test level.
The normal test level ensures that each memory cell stores both a 0 and a 1, and checks that all cells are separately addressable. The quick test level only does the 0s and 1s test, and typically misses address line problems. The extended test uses patterns to test for adjacent cell interference problems. The default test level is normal. See -t option.
Use with the -t option to specify the maximum number of allowed errors. If not specified, a default of 32 is assumed.
Use with the unconfigure command to set the self-cancelling timeout. The default value is 60 and the unit is seconds. A value of 0 means no timeout.
Test an unconfigured bank of memory. Specify the test level using the -o quick | normal | extended option.
cfgadm exits with a 0 (success) if the test was able to run on the memory bank. The result of the test is available in the condition for the attachment point.
Verbose option. Use this option in combination with the -t option to display detailed progress and results of tests.
For all pages of memory in use on the specified memory bank, a relocation operation as used in the unconfigure command is attempted. The success of this operation does not guarantee that the bank can be unconfigured. Failure indicates that it probably cannot be unconfigured. This option is for test purposes only.
The following operand is supported:
The attachment points for memory banks are published by instances of the address controller (ac) driver (ac#). One instance of the ac driver is created for each system board, but only those instances associated with CPU/Memory boards publish the two bank attachment points, bank0 and bank1.
This form conforms to the logical ap_id specification given in cfgadm(1M). The corresponding physical ap_ids are listed in the FILES section.
The ac driver instance numbering has no relation to the slot number for the corresponding board. The full physical attachment point identifier has the slot number incorporated into it as twice the slot number in hexadecimal directly following the fhc@ part.
attachment points
hardware specific library file
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWkvm.u |
cfgadm(1M), cfgadm_sysctrl(1M), config_admin(3CFGADM), attributes(5)
Sun Enterprise 6x00, 5x00, 4x00 and 3x00 Systems Dynamic Reconfiguration User's Guide
Refer to the Sun Enterprise 6x00, 5x00, 4x00 and 3x00 Systems Dynamic Reconfiguration User's Guide for additional details regarding dynamic reconfiguration of EXX00 system CPU/Memory boards.
