Name | Synopsis | Description | Options | Operands | Examples | Files | Exit Status | Attributes | See Also | Notes
coreadm [-g pattern] [-G content] [-i pattern] [-I content]
     [-d option]... [-e option]...
coreadm [-p pattern] [-P content] [pid]...
coreadm -u
coreadm specifies the name and location of core files produced by abnormally-terminating processes. See core(4).
Only users who have the sys_admin privilege can execute the first form of the SYNOPSIS. This form configures system-wide core file options, including a global core file name pattern and a core file name pattern for the init(1M) process. All settings are saved in coreadm's configuration file /etc/coreadm.conf to set at boot. See init(1M).
Nonprivileged users can execute the second form of the SYNOPSIS. This form specifies the file name pattern and core file content that the operating system uses to generate a per-process core file.
Only users who have the sys_admin privilege can execute the third form of the SYNOPSIS. This form updates all system-wide core file options, based on the contents of /etc/coreadm.conf. Normally, this option is used on reboot when starting svc:/system/coreadm:default.
A core file name pattern is a normal file system path name with embedded variables, specified with a leading % character. The variables are expanded from values that are effective when a core file is generated by the operating system. The possible embedded variables are as follows:
Executable file directory name, up to a maximum of MAXPATHLEN characters
Executable file name, up to a maximum of MAXCOMLEN characters
Effective group-ID
Machine name (uname -m)
System node name (uname -n)
Process-ID
Decimal value of time(2)
Effective user-ID
Name of the zone in which process executed (zonename)
Literal %
For example, the core file name pattern /var/core/core.%f.%p would result, for command foo with process-ID 1234, in the core file name /var/core/core.foo.1234.
A core file content description is specified using a series of tokens to identify parts of a process's binary image:
Anonymous private mappings, including thread stacks that are not main thread stacks
CTF type information sections for loaded object files
Writable private file mappings
DISM mappings
Process heap
ISM mappings
Read-only private file mappings
Anonymous shared mappings
Shared mappings that are backed by files
System V shared memory
Process stack
Symbol table sections for loaded object files
Readable and executable private file mappings
In addition, you can use the token all to indicate that core files should include all of these parts of the process's binary image. You can use the token none to indicate that no mappings are to be included. The default token indicates inclusion of the system default content (stack+heap+shm+ism+dism+text+data+rodata+anon+shanon+ctf). The /proc file system data structures are always present in core files regardless of the mapping content.
You can use + and - to concatenate tokens. For example, the core file content default-ism would produce a core file with the default set of mappings without any intimate shared memory mappings.
The coreadm command with no arguments reports the current system configuration, for example:
| $ coreadm
    global core file pattern: /var/core/core.%f.%p
    global core file content: all
      init core file pattern: core
      init core file content: default
           global core dumps: enabled
      per-process core dumps: enabled
     global setid core dumps: enabled
per-process setid core dumps: disabled
    global core dump logging: disabled |
The coreadm command with only a list of process-IDs reports each process's per-process core file name pattern, for example:
| $ coreadm 278 5678 278: core.%f.%p default 5678: /home/george/cores/%f.%p.%t all-ism |
Only the owner of a process or a user with the proc_owner privilege can interrogate a process in this manner.
When a process is dumping core, up to three core files can be produced: one in the per-process location, one in the system-wide global location, and, if the process was running in a local (non-global) zone, one in the global location for the zone in which that process was running. Each core file is generated according to the effective options for the corresponding location.
When generated, a global core file is created in mode 600 and owned by the superuser. Nonprivileged users cannot examine such files.
Ordinary per-process core files are created in mode 600 under the credentials of the process. The owner of the process can examine such files.
A process that is or ever has been setuid or setgid since its last exec(2) presents security issues that relate to dumping core. Similarly, a process that initially had superuser privileges and lost those privileges through setuid(2) also presents security issues that are related to dumping core. A process of either type can contain sensitive information in its address space to which the current nonprivileged owner of the process should not have access. If setid core files are enabled, they are created mode 600 and owned by the superuser.
The following options are supported:
Disable the specified core file option. See the -e option for descriptions of possible options.
Multiple -e and -d options can be specified on the command line. Only users with the sys_admin privilege can use this option.
Enable the specified core file option. Specify option as one of the following:
Allow core dumps that use global core pattern.
Allow set-id core dumps that use global core pattern.
Generate a syslog(3C) message when generation of a global core file is attempted.
Allow core dumps that use per-process core pattern.
Allow set-id core dumps that use per-process core pattern.
Set the global core file name pattern to pattern. The pattern must start with a / and can contain any of the special % variables that are described in the DESCRIPTION.
Set the global core file content to content. You must specify content by using the tokens that are described in the DESCRIPTION.
Set the default per-process core file name to pattern. This changes the per-process pattern for any process whose per-process pattern is still set to the default. Processes that have had their per-process pattern set or are descended from a process that had its per-process pattern set (using the -p option) are unaffected. This default persists across reboot.
Only users with the sys_admin or proc_owner privilege can use this option.
Set the default per-process core file content to content. This changes the per-process content for any process whose per-process content is still set to the default. Processes that have had their per-process content set or are descended from a process that had its per-process content set (using the -P option) are unaffected. This default persists across reboot.
Only users with the sys_admin or proc_owner privileges can use this option.
Set the per-process core file name pattern to pattern for each of the specified process-IDs. The pattern can contain any of the special % variables described in the DESCRIPTION and need not begin with /. If the pattern does not begin with /, it is evaluated relative to the directory that is current when the process generates a core file.
A nonprivileged user can apply the -p option only to processes that are owned by that user. A user with the proc_owner privilege can apply the option to any process. The per-process core file name pattern is inherited by future child processes of the affected processes. See fork(2).
If no process-IDs are specified, the -p option sets the per-process core file name pattern to pattern on the parent process (usually the shell that ran coreadm).
Set the per-process core file content to content for each of the specified process-IDs. The content must be specified by using the tokens that are described in the DESCRIPTION.
If no process-IDs are specified, the -P option sets the per-process file content to content on the parent process (usually the shell that ran coreadm).
Update system-wide core file options from the contents of the configuration file /etc/coreadm.conf. If the configuration file is missing or contains invalid values, default values are substituted. Following the update, the configuration file is resynchronized with the system core file configuration.
When executed from a user's $HOME/.profile or $HOME/.login, the following command sets the core file name pattern for all processes that are run during the login session:
| example$ coreadm -p core.%f.%p |
Note that since the process-ID is omitted, the per-process core file name pattern will be set in the shell that is currently running and is inherited by all child processes.
The following command dumps all of a user's core dumps into the corefiles subdirectory of the home directory, discriminated by the system node name. This command is useful for users who use many different machines but have a shared home directory.
| example$ coreadm -p $HOME/corefiles/%n.%f.%p 1234 |
The following commands set up the system to produce core files in the global repository only if the executables were run from /usr/bin or /usr/sbin.
| example# mkdir -p /var/cores/usr/bin example# mkdir -p /var/cores/usr/sbin example# coreadm -G all -g /var/cores/%d/%f.%p.%n |
The following exit values are returned:
Successful completion.
A fatal error occurred while either obtaining or modifying the system core file configuration.
Invalid command-line options were specified.
| ATTRIBUTE TYPE | ATTRIBUTE VALUE |
| Availability | SUNWcsu |
gcore(1), svcs(1), init(1M), svcadm(1M), exec(2), fork(2), setuid(2), time(2), syslog(3C), core(4), attributes(5), smf(5)
In a local (non-global) zone, the global settings apply to processes running in that zone. In addition, the global zone's apply to processes run in any zone.
The term global settings refers to settings which are applied to the system or zone as a whole, and does not necessarily imply that the settings are to take effect in the global zone.
The coreadm service is managed by the service management facility, smf(5), under the service identifier:
| svc:/system/coreadm:default |
Administrative actions on this service, such as enabling, disabling, or requesting restart, can be performed using svcadm(1M). The service's status can be queried using the svcs(1) command.
