Name | Synopsis | Description | Options | Operands | Examples | Files | Attributes | See Also
/usr/sbin/kdb5_util [-d dbname] [-f stashfile_name] [-k mkeytype] [-m ] [-M mkeyname] [-P password] [-r realm] [-x db_args]... cmd
The kdb5_util utility enables you to create, dump, load, and destroy the Kerberos V5 database. You can also use kdb5_util to create a stash file containing the Kerberos database master key.
The following options are supported:
Specify the database name. .db is appended to whatever name is specified. You can specify an absolute path. If you do not specify the -d option, the default database name is /var/krb5/principal.
Specify the stash file name. You can specify an absolute path.
Specify the master key type. Valid values are des3-cbc-sha1, des-cbc-crc, des-cbc-md5, des-cbc-raw, arcfour-hmac-md5, arcfour-hmac-md5-exp, aes128-cts-hmac-sha1-96, and aes256-cts-hmac-sha1-96.
Enter the master key manually.
Specify the master key name.
Use the specified password instead of the stash file.
Use realm as the default database realm.
Pass database-specific arguments to kadmin. Supported arguments are for LDAP and the Berkeley-db2 plug-in. These arguments are:
LDAP simple bind DN for authorization on the directory server. Overrides the ldap_kadmind_dn parameter setting in krb5.conf(4).
Bind password.
For the Berkeley-db2 plug-in, specifies a name for the Kerberos database.
Maximum number of server connections.
Directory server connection port.
The following operands are supported:
Specifies whether to create, destroy, dump, or load the database, or to create a stash file.
You can specify the following commands:
Creates the database specified by the -d option. You will be prompted for the database master password. If you specify -s, a stash file is created as specified by the -f option. If you did not specify -f, the default stash file name is /var/krb5/.k5.realm. If you use the -f, -k, or -M options when you create a database, then you must use the same options when modifying or destroying the database.
Destroys the database specified by the -d option.
Creates a stash file. If -f was not specified, the default stash file name is /var/krb5/.k5.realm. You will be prompted for the master database password. This command is useful when you want to generate the stash file from the password.
Dumps the current Kerberos and KADM5 database into an ASCII file. By default, the database is dumped in current format, “kdb5_util load_dumpversion 5”. If filename is not specified or is the string “-”, the dump is sent to standard output. Options are as follows:
Causes the dump to be in the Kerberos 5 Beta 5 and earlier dump format (“kdb5_edit load_dump version 2.0”).
Causes the dump to be in the Kerberos 5 Beta 6 format (“kdb5_edit load_dump version 3.0”).
Causes the dump to be in the Kerberos 5 Beta 7 format (“kdb5_util load_dump version 4”). This was the dump format produced on releases prior to 1.2.2.
Causes the dump to be in ovsec_adm_export format.
Causes the name of each principal and policy to be displayed as it is dumped.
Prompts for a new master key. This new master key will be used to re-encrypt the key data in the dumpfile. The key data in the database will not be changed.
The filename of a stash file. The master key in this stash file will be used to re-encrypt the key data in the dumpfile. The key data in the database will not be changed.
Dumps in reverse order. This might recover principals that do not dump normally, in cases where database corruption has occured.
Causes the dump to walk the database recursively (btree only). This might recover principals that do not dump normally, in cases where database corruption has occurred. In cases of such corruption, this option will probably retrieve more principals than will the -rev option.
Loads a database dump from filename into dbname. Unless the -old or -b6 option is specified, the format of the dump file is detected automatically and handled appropriately. Unless the -update option is specified, load creates a new database containing only the principals in the dump file, overwriting the contents of any existing database. The -old option requires the database to be in the Kerberos 5 Beta 5 or earlier format (“kdb5_edit load_dump version 2.0”).
Requires the database to be in the Kerberos 5 Beta 6 format (“kdb5_edit load_dump version 3.0”).
Requires the database to be in the Kerberos 5 Beta 7 format (“kdb5_util load_dump version 4”).
Requires the database to be in ovsec_adm_import format. Must be used with the -update option.
Requires the database to be stored as a hash. If this option is not specified, the database will be stored as a btree. This option is not recommended, as databases stored in hash format are known to corrupt data and lose principals.
Records from the dump file are added to or updated in the existing database. Otherwise, a new database is created containing only what is in the dump file and the old one is destroyed upon successful completion.
Required argument that specifies a path to a file containing database dump.
Required argument that overrides the value specified on the command line or overrides the default.
Optional argument that is derived from dbname if not specified.
The following example creates a file named slavedata that contains the information about two principals, jdb@ACME.COM and pak@ACME.COM.
# /usr/krb5/bin/kdb5_util dump -verbose slavedata jdb@ACME.COM pak@ACME.COM |
Kerberos principal database.
Kerberos administrative database. Contains policy information.
Lock file for the Kerberos administrative database. This file works backwards from most other lock files (that is, kadmin exits with an error if this file does not exist).
The update log file for incremental propagation.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWkdcu |
Interface Stability |
Evolving |
kpasswd(1), gkadmin(1M), kadmin(1M), kadmind(1M), kadmin.local(1M), kdb5_ldap_util(1M), kproplog(1M), kadm5.acl(4), kdc.conf(4), attributes(5), kerberos(5)
