Name | Synopsis | Description | Files | Attributes | See Also | Notes
/usr/lib/krb5/ktkt_warnd
ktkt_warnd is a daemon on Kerberos clients that can warn users when their Kerberos tickets are about to expire or renew the tickets before they expire. It is invoked by inetd when a ticket-granting ticket (TGT) is obtained for the first time, such as after using the kinit command. ktkt_warnd can be configured through the /etc/krb5/warn.conf file on the client. In warn.conf, you can specify that you be supplied notice, through syslog or terminal or mail, of ticket expiration or to renew the TGT.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Evolving |
The ktkt_warnd service is managed by the service management facility, smf(5), under the service identifier:
svc:/network/security/ktkt_warn:default |
Administrative actions on this service, such as enabling, disabling, or requesting restart, can be performed using svcadm(1M). Responsibility for initiating and restarting this service is delegated to inetd(1M). Use inetadm(1M) to make configuration changes and to view configuration information for this service. The service's status can be queried using the svcs(1) command.
