Name | Synopsis | Description | Options | Exit Status | Files | Attributes | See Also
/usr/sbin/lucurr [-l error_log] [-m mount_point] [-o outfile] [-X]
The lucurr command is part of a suite of commands that make up the Live Upgrade feature of the Solaris operating environment. See live_upgrade(5) for a description of the Live Upgrade feature.
The lucurr command displays the name of the currently running boot environment (BE). If no BEs are configured on the system, lucurr displays the message "No Boot Environments are defined". Note that lucurr reports only the name of the current BE, not the BE that will be active upon the next reboot. Use lustatus(1M) or luactivate(1M) for this information.
The lucurr command requires root privileges.
The lucurr command has the following options:
Error and status messages are sent to error_log, in addition to where they are sent in your current environment.
Returns the name of the BE that owns mount_point, where mount_point is the mount point of a BE's root file system. This can be a mount point of the current BE or the mount point of a BE other than the current BE. If the latter, the file system of the BE must have been mounted with lumount(1M) or mount(1M) before entering this option.
All command output is sent to outfile, in addition to where it is sent in your current environment.
Enable XML output. Characteristics of XML are defined in DTD, in /usr/share/lib/xml/dtd/lu_cli.dtd.<num>, where <num> is the version number of the DTD file.
list of BEs on the system
Live Upgrade DTD (see -X option)
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWluu |
luactivate(1M), lucancel(1M), lucompare(1M), lucreate(1M), ludelete(1M), ludesc(1M), lufslist(1M), lumake(1M), lumount(1M), lurename(1M), lustatus(1M), luupgrade(1M), lutab(4), attributes(5), live_upgrade(5)
