Name | Synopsis | Description | Options | Operands | Usage | Exit Status | Files | Attributes | See Also | Notes
/usr/lib/nfs/nfsd [-a] [-c #_conn] [-l listen_backlog]
[-p protocol] [-t device] [nservers]
nfsd is the daemon that handles client file system requests. Only users with {PRIV_SYS_NFS} and sufficient privileges to write to /var/run can run this daemon.
The nfsd daemon is automatically invoked using share(1M) with the -a option.
By default, nfsd starts over the TCP and UDP transports for versions 2 and 3. By default, it starts over the TCP for version 4. You can change this with the -p option.
A previously invoked nfsd daemon started with or without options must be stopped before invoking another nfsd command.
Administrators wanting to change startup parameters for nfsd should, as root, make changes in the /etc/default/nfs file. See nfs(4).
The following options are supported:
Start a NFS daemon over all available connectionless and connection-oriented transports, including UDP and TCP. Equivalent of setting the NFSD_PROTOCOL parameter to ALL in the nfs file.
This sets the maximum number of connections allowed to the NFS server over connection-oriented transports. By default, the number of connections is unlimited. Equivalent of the NFSD_MAX_CONNECTIONS parameter in the nfs file.
Set connection queue length for the NFS TCP over a connection-oriented transport. The default value is 32 entries. Equivalent of the NFSD_LISTEN_BACKLOG parameter in the nfs file.
Start a NFS daemon over the specified protocol. Equivalent of the NFSD_PROTOCOL parameter in the nfs file.
Start a NFS daemon for the transport specified by the given device. Equivalent of the NFSD_DEVICE parameter in the nfs file.
The following operands are supported:
This sets the maximum number of concurrent NFS requests that the server can handle. This concurrency is achieved by up to nservers threads created as needed in the kernel. nservers should be based on the load expected on this server. 16 is the usual number of nservers. If nservers is not specified, the maximum number of concurrent NFS requests will default to 1. Equivalent of the NFSD_SERVERS parameter in the nfs file.
If the NFS_PORTMON variable is set in /etc/system, then clients are required to use privileged ports (ports < IPPORT_RESERVED) to get NFS services. This variable is equal to zero by default. This variable has been moved from the “nfs” module to the “nfssrv” module. To set the variable, edit the /etc/system file and add this entry:
set nfssrv:nfs_portmon = 1
Client machine pointer to an open-but-unlinked file.
Contains startup parameters for nfsd.
System configuration information file.
Directories used by the server to manage client state information. These directories should not be removed.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWnfssu |
ps(1), svcs(1), mountd(1M), share(1M), svcadm(1M), nfs(4), sharetab(4), system(4), attributes(5), smf(5)
System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Manually starting and restarting nfsd is not recommended. If it is necessary to do so, use svcadm to enable or disable the nfs service (svc:/network/nfs/server). If it is disabled, it will be enabled by share_nfs(1M), unless its application/auto_enable property is set to false. See the System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP), and svcadm(1M) for more information.
The nfsd service is managed by the service management facility, smf(5), under the service identifier:
svc:/network/nfs/server |
Administrative actions on this service, such as enabling, disabling, or requesting restart, can be performed using svcadm(1M). The service's status can be queried using the svcs(1) command.
If nfsd is killed with SIGTERM, it will not be restarted by the service management facility. Instead, nfsd can be restarted by other signals, such as SIGINT.
