Name | Synopsis | Description | Options | Examples | Exit Status | Attributes | See Also
/usr/sbin/poolbind -p poolname [-i idtype] id...
/usr/sbin/poolbind -q pid...
/usr/sbin/poolbind -Q pid...
The poolbind command allows an authorized user to bind zones, projects, tasks, and processes to pools. It can also allow a user to query a process to determine which pool the process is bound to.
The following options are supported:
This option, together with the idlist arguments, specifies one or more processes to which the poolbind command is to apply. The interpretation of idlist depends on the value of idtype. The valid idtype arguments and corresponding interpretations of idlist are as follows:
idlist is a list of process IDs. Binds the specified processes to the specified pool. This is the default behavior if no idtype is specified.
idlist is a list of task IDs. Bind all processes within the list of task IDs to the specified pool.
idlist is a list of project IDs. Bind all processes within the list of projects to the specified pool. Each project ID can be specified as either a project name or a numerical project ID. See project(4).
idlist is a list of zone IDs. Bind all processes within the list of zones to the specified pool. Each zone ID can be specified as either a zone name or a numerical zone ID. See zones(5).
Specifies the name of a pool to which the specified zone, project, tasks, or processes are to be bound.
Queries the pool bindings for a given list of process IDs. If the collection of resources associated with the process does not correspond to any currently existing pool, or if there are multiple pools with the set of resources that the process is bound to, the query fails for that particular process ID.
Queries the resource bindings for a given list of process IDs. The resource bindings are each reported on a separate line.
The following command binds all processes in projects 5 and 7 to the pool web_app:
example# /usr/sbin/poolbind -p web_app -i projid 5 7 |
The following command binds the running shell to the pool web_app:
example# /usr/sbin/poolbind -p web_app $$ |
The following command queries the bindings to verify that the shell is bound to the given pool:
example# /usr/sbin/poolbind -q $$ |
The following command queries the bindings to verify that the shell is bound to the given resources:
example# /usr/sbin/poolbind -Q $$ |
The following exit values are returned:
Successful completion.
Requested operation could not be completed.
Invalid command line options were specified.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWpool |
Interface Stability |
See below. |
The invocation is Evolving. The output is Unstable.
pooladm(1M), poolcfg(1M), libpool(3LIB), project(4), attributes(5), zones(5)
System Administration Guide: Solaris Containers-Resource Management and Solaris Zones
