Name | Synopsis | Description | Options | Operands | Examples | Exit Status | Files | Attributes | See Also | Notes
projadd [-n] [-f filename] [-p projid [-o]] [-c comment]
[-U user [,user]... ] [-G group [,group]... ]
[ [-K name [=value [,value]...]...]] project
projadd adds a new project entry to the /etc/project file. If the files backend is being used for the project database, the new project is available for use immediately upon the completion of the projadd command.
The following options are supported:
Add a project comment. Comments are stored in the project's entry in the /etc/project file. Generally, comments contain a short description of the project and are used as the field for the project's full name.
Specify comment as a text string. comment cannot contain a colon (:) or NEWLINE.
Specify the project file to modify. If no filename is specified, the system project file, /etc/project, is modified.
Specify a group list for the project.
Specify an attribute list for the project. Multiple -K options can be specified to set values on multiple keys, such as:
-K key1=value1 -K "key2=(value2a),(value2b)"
Resource control attributes use parentheses to specify values for a key. Because many user shells interpret parentheses as special characters, it is best to enclose an argument to -K that contains parentheses with double quotes, as shown above and in EXAMPLES, below. See resource_controls(5) for a description of the resource controls you can specify for a project.
Syntax check. Check the format of the existing system project file and modifications only. The contents of the existing project file, such as user names, group names, and resources that are specified in the project attributes are not checked.
This option allows the project ID specified by the -p option to be non-unique within the project file.
Set the project ID of the new project.
Specify projid as a non-negative decimal integer below UID_MAX as defined in limits.h. projid defaults to the next available unique number above the highest number currently assigned. For example, if projids 100, 105, and 200 are assigned, the next default projid is 201. projids between 0-99 are reserved by SunOS.
Specify a user list for the project.
The following operands are supported:
The name of the project to create. The project operand is a string consisting of characters from the set of alphabetic characters, numeric characters, underline (_), and hyphen (-). The period ('.') is reserved for projects with special meaning to the operating system. The first character of the project name must be a letter. An error message is displayed if these restrictions are not met.
The following command creates the project salesaudit and sets the resource controls specified as arguments to the -K option.
projadd -p 111 -G sales,finance -c "Auditing Project" \ -K "rcap.max-rss=10GB" \ -K "process.max-file-size=(priv,50MB,deny)" \ -K "task.max-lwps=(priv,100,deny)" salesaudit
This command would produce the following entry in /etc/project:
salesaudit:111:Auditing Project::sales,finance: \ process.max-file-size=(priv,52428800,deny); \ rcap.max-rss=10737418240;task.max-lwps=(priv,100,deny)
Note that the preceding would appear as one line in /etc/project.
Comparing the projadd command and resulting output in /etc/project, note the effect of the scaling factor in the resource cap (rcap.max-rss=10GB) and the resource control (process.max-file-size=(priv,50MB,deny)). Modifiers, such as B, KB, and MB, and scaling factors are specified in resource_controls(5).
The following exit values are returned:
Successful completion.
The command syntax was invalid. A usage message for projadd is displayed.
An invalid argument was provided to an option.
The projid given with the -p option is already in use.
The project files contain an error. See project(4).
The project to be added, group, user, or resource does not exist.
The project is already in use.
Cannot update the /etc/project file.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWesu |
Interface Stability |
See below. |
Invocation is evolving. Human readable output is unstable.
projects(1), groupadd(1M), groupdel(1M), groupmod(1M), grpck(1M), projdel(1M), projmod(1M), useradd(1M), userdel(1M), usermod(1M), project(4), attributes(5), resource_controls(5)
In case of an error, projadd prints an error message and exits with a non-zero status.
projadd adds a project definition only on the local system. If a network name service such as NIS or LDAP is being used to supplement the local /etc/project file with additional entries, projadd cannot change information supplied by the network name service.
