Name | Synopsis | Description | Options | Return Values | Examples | Files | Attributes | See Also | Notes
/usr/snadm/bin/soldelapp [-r registry] -n name
soldelapp removes an application from the Solstice application registry. After removal, the application is no longer displayed in the Solstice Launcher main window (see solstice(1M)).
Define the full path name of the Solstice registry file.
Define the name of the tool to be removed.
When executed without options, soldelapp uses /opt/SUNWadm/etc/.solstice_registry (the default registry path).
on success
on failure
if the registry is locked
if name is not found in the registry
if the named registry or default registry is not found
The following removes an application called Disk Manager from the Solstice application registry and the Solstice Launcher main window.
# soldelapp -r /opt/SUNWadm/etc/.solstice_registry -n "Disk Manager" |
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWsadml |
Globally registered applications are used by local and remote users sharing the software in a particular /opt directory. They can be removed only using soldelapp.
