Name | Synopsis | Description | Options | Examples | Exit Status | Attributes | See Also
/usr/lib/inet/wanboot/keygen -c -o net=a.b.c.d ,cid=client_ID,type=3des
/usr/lib/inet/wanboot/keygen -c -o net=a.b.c.d ,cid=client_ID,type=aes
/usr/lib/inet/wanboot/keygen -m
/usr/lib/inet/wanboot/keygen -c -o net=a.b.c.d ,cid=client_ID,type=sha1
/usr/lib/inet/wanboot/keygen -d -m
/usr/lib/inet/wanboot/keygen -c -o net=a.b.c.d ,cid=client_ID,type=keytype
The keygen utility has three purposes:
Using the -c flag, to generate and store per-client 3DES/AES encryption keys, avoiding any DES weak keys.
Using the -m flag, to generate and store a “master” HMAC SHA-1 key for WAN install, and to derive from the master key per-client HMAC SHA-1 hashing keys, in a manner described in RFC 3118, Appendix A.
Using the -d flag along with either the -c or -m flag to indicate the key repository, to display a key of type specified by keytype, which must be one of 3des, aes, or sha1.
The net and cid arguments are used to identify a specific client. Both arguments are optional. If the cid option is not provided, the key being created or displayed will have a per-network scope. If the net option is not provided, then the key will have a global scope. Default net and code values are used to derive an HMAC SHA-1 key if the values are not provided by the user.
The following options are supported:
Generate and store per-client 3DES/AES encryption keys, avoiding any DES weak keys. Also generates and stores per-client HMAC SHA-1 keys. Used in conjunction with -o.
Display a key of type specified by keytype, which must be one of 3des, aes, or sha1. Use -d with -m or with -c and -o.
Generate and store a “master” HMAC SHA-1 key for WAN install.
Specifies the WANboot client and/or keytype.
# keygen -m |
# keygen -c -o net=172.16.174.0,cid=010003BA0E6A36,type=sha1 # keygen -d -c -o net=172.16.174.0,cid=010003BA0E6A36,type=sha1 |
# keygen -c -o net=172.16.174.0,type=3des # keygen -d -o net=172.16.174.0,type=3des |
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWwbsup |
Interface Stability |
Obsolete |
