Name | Synopsis | Description | Return Values | Errors | Examples | Usage | Attributes | See Also
#include <sys/stat.h> #include <fcntl.h> int creat(const char *path, mode_t mode);
The function call
creat(path, mode)
is equivalent to:
open(path, O_WRONLY | O_CREAT | O_TRUNC, mode)
Refer to open(2).
Refer to open(2).
The following example creates the file /tmp/file with read and write permissions for the file owner and read permission for group and others. The resulting file descriptor is assigned to the fd variable.
#include <fcntl.h> ... int fd; mode_t mode = S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH; char *filename = "/tmp/file"; ... fd = creat(filename, mode); ...
The creat() function has a transitional interface for 64-bit file offsets. See lf64(5).
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard |
MT-Level |
Async-Signal-Safe |
