Name | Synopsis | Description | Return Values | Errors | Examples | Attributes | See Also
#include <sys/types.h> #include <sys/stat.h> int mkdir(const char *path, mode_t mode);
The mkdir() function creates a new directory named by the path name pointed to by path. The mode of the new directory is initialized from mode (see chmod(2) for values of mode). The protection part of the mode argument is modified by the process's file creation mask (see umask(2)).
The directory's owner ID is set to the process's effective user ID. The directory's group ID is set to the process's effective group ID, or if the S_ISGID bit is set in the parent directory, then the group ID of the directory is inherited from the parent. The S_ISGID bit of the new directory is inherited from the parent directory.
If path names a symbolic link, mkdir() fails and sets errno to EEXIST.
The newly created directory is empty with the exception of entries for itself (.) and its parent directory (..).
Upon successful completion, mkdir() marks for update the st_atime, st_ctime and st_mtime fields of the directory. Also, the st_ctime and st_mtime fields of the directory that contains the new entry are marked for update.
Upon successful completion, 0 is returned. Otherwise, -1 is returned, no directory is created, and errno is set to indicate the error.
The mkdir() function will fail if:
Either a component of the path prefix denies search permission or write permission is denied on the parent directory of the directory to be created.
The directory where the new file entry is being placed cannot be extended because the user's quota of disk blocks on that file system has been exhausted; the new directory cannot be created because the user's quota of disk blocks on that file system has been exhausted; or the user's quota of inodes on the file system where the file is being created has been exhausted.
The named file already exists.
The path argument points to an illegal address.
An attempt was made to create an extended attribute that is a directory.
An I/O error has occurred while accessing the file system.
Too many symbolic links were encountered in translating path.
A loop exists in symbolic links encountered during resolution of the path argument.
The maximum number of links to the parent directory would be exceeded.
The length of the path argument exceeds PATH_MAX, or the length of a path component exceeds NAME_MAX while _POSIX_NO_TRUNC is in effect.
A component of the path prefix does not exist or is a null pathname.
The path argument points to a remote machine and the link to that machine is no longer active.
No free space is available on the device containing the directory.
A component of the path prefix is not a directory.
The path prefix resides on a read-only file system.
The mkdir() function may fail if:
As a result of encountering a symbolic link in resolution of the path argument, the length of the substituted pathname string exceeded {PATH_MAX}.
The following example demonstrates how to create a directory named /home/cnd/mod1, with read, write, and search permissions for owner and group, and with read and search permissions for others.
#include <sys/types.h> #include <sys/stat.h> int status; ... status = mkdir("/home/cnd/mod1", S_IRWXU | S_IRWXG | S_IROTH | S_IXOTH);
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard |
MT-Level |
Async-Signal-Safe |
