Name | Synopsis | Description | Return Values | Errors | Attributes | See Also
#include <port.h> int port_alert(int port, int flags, int events, void *user);
The port_alert() function transitions a port into or out of alert mode. A port in alert mode immediately awakens all threads blocked in port_get(3C) or port_getn(3C). These threads return with an alert notification that consists of a single port_event_t structure with the source PORT_SOURCE_ALERT. Subsequent threads trying to retrieve events from a port that is in alert mode will return immediately with the alert notification.
A port is transitioned into alert mode by calling the port_alert() function with a non-zero events parameter. The specified events and user parameters will be made available in the portev_events and the portev_user members of the alert notification, respectively. The flags argument determines the mode of operation of the alert mode:
If flags is set to PORT_ALERT_SET, port_alert() sets the port in alert mode independent of the current state of the port. The portev_events and portev_user members are set or updated accordingly.
If flags is set to PORT_ALERT_UPDATE and the port is not in alert mode, port_alert() transitions the port into alert mode. The portev_events and portev_user members are set accordingly.
If flags is set to PORT_ALERT_UPDATE and the port is already in alert mode, port_alert() returns with an error value of EBUSY.
PORT_ALERT_SET and PORT_ALERT_UPDATE are mutually exclusive.
A port is transitioned out of alert mode by calling the port_alert() function with a zero events parameter.
Events can be queued to a port that is in alert mode, but they will not be retrievable until the port is transitioned out of alert mode.
Upon succesful completion, 0 is returned. Otherwise, -1 is returned and errno is set to indicate the error.
The port_alert() function will fail if:
The port identifier is not valid.
The port argument is not an event port file descriptor.
The port is already in alert mode.
Mutually exclusive flags are set.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
all |
Availability |
SUNWcsr, SUNWhea |
Interface Stability |
Evolving |
MT-Level |
Safe |
