Name | Synopsis | Description | Return Values | Attributes | See Also | Notes
cc [ flag ... ] file... -lcurses [ library ... ] #include <curses.h> int insch(chtype ch);
int winsch(WINDOW *win, chtype ch);
int mvinsch(int y, int x, chtype ch);
int mvwinsch(WINDOW *win, int y, int x, chtype ch);
With these routines, the character ch is inserted before the character under the cursor. All characters to the right of the cursor are moved one space to the right, with the possibility of the rightmost character on the line being lost. The cursor position does not change (after moving to y, x, if specified). (This does not imply use of the hardware insert character feature.)
All routines return the integer ERR upon failure and an integer value other than ERR upon successful completion.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
MT-Level |
Unsafe |
The header <curses.h> automatically includes the headers <stdio.h> and <unctrl.h>.
Note that insch(), mvinsch(), and mvwinsch() may be macros.
