Name | Synopsis | Description | Parameters | Return Values | Errors | Attributes | See Also
cc [ flag... ] file... -I /usr/xpg4/include -L /usr/xpg4/lib \ -R /usr/xpg4/lib -lcurses [ library... ] c89 [ flag... ] file... -lcurses [ library... ] #include <curses.h> int echo_wchar(const cchar_t *wch);
int wecho_wchar(WINDOW *win, const cchar_t *wch);
The echo_wchar() function produces the same effect as calling add_wch(3XCURSES) and then refresh(3XCURSES). The wecho_wchar() function produces the same effect as calling wadd_wch(3XCURSES) and then wrefresh(3XCURSES).
Is a pointer to the complex character to be written to the window.
Is a pointer to the window in which the character is to be added.
On success, these functions return OK. Otherwise, they return ERR.
None.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard |
MT-Level |
Unsafe |
add_wch(3XCURSES), doupdate(3XCURSES), echochar(3XCURSES), libcurses(3XCURSES), attributes(5), standards(5)
