Name | Synopsis | Description | Return Values | Attributes | See Also | Notes
cc [ flag ... ] file ... -lcurses [ library ... ] #include <curses.h> int move(int y, int x);
int wmove(WINDOW *win, int y, int x);
With these routines, the cursor associated with the window is moved to line y and column x. This routine does not move the physical cursor of the terminal until refresh() is called. The position specified is relative to the upper left-hand corner of the window, which is (0,0).
These routines return the integer ERR upon failure and an integer value other than ERR upon successful completion.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
MT-Level |
Unsafe |
The header <curses.h> automatically includes the headers <stdio.h> and <unctrl.h>.
Note that move() may be a macro.
