Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc -flag … file …-lnsl [ -library … ] #include <netdb.h> int getipsecprotobyname(const char *proto_name
char *getipsecprotobynum(int proto_nump
Use the getipsecprotobyname() and getipsecprotobynum() functions to obtain the IPsec algorithm mappings that are defined by ipsecalgs(1M). You can also use the getipsecprotobyname() and getipsecprotobynum() functions in conjunction with getipsecalgbyname(3NSL) and getipsecalgbynum(3NSL) to obtain information about the supported IPsec algorithms. The IPsec algorithms and associated protocol name spaces are defined by RFC 2407.
getipsecprotobyname() takes as an argument the name of an IPsec protocol and returns its assigned protocol number. The character string returned by the getipsecprotobyname() function must be freed by the called when it is no longer needed.
getipsecprotobynum() takes as an argument a protocol number and returns the corresponding protocol name.
The following protocol numbers are pre-defined:
Defines the encryption algorithms (transforms) that can be used by IPsec to provide data confidentiality.
Defines the authentication algorithms (transforms) that can be used by IPsec to provide authentication.
A pointer to the name of an IPsec protocol.
A pointer to a protocol number. conditions.
The getipsecprotobyname() function returns a protocol number upon success, or –1 if the protocol specified does not exist.
The getipsecprotobynum() function returns a protocol name upon success, or the NULL value if the protocol number specified does not exist.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWcsl (32 bit) |
SUNWcslx (64 bit) |
MT Level |
MT Safe |
Interface Stability |
Evolving |
ipsecalgs(1M), getipsecalgbyname(3NSL), getipsecalgbyname(3NSL), attributes(5)
Piper, D. RFC 2407, The Internet IP Security Domain of Interpretation for ISAKMP. Network Working Group. November, 1998.
