Name | Synopsis | Description | Parameters | Errors | Attributes | See Also
cc [ flag... ] file... -lgss [ library... ] #include <gssapi/gssapi.h> OM_uint32 gss_indicate_mechs(OM_uint32 *minor_status, gss_OID_set *mech_set);
The gss_indicate_mechs() function enables an application to determine available underlying security mechanisms.
The parameter descriptions for gss_indicate_mechs() follow:
A mechanism-specific status code.
Set of supported mechanisms. The returned gss_OID_set value will be a dynamically-allocated OID set that should be released by the caller after use with a call to gss_release_oid_set(3GSS).
The gss_indicate_mechs() function may return the following status codes:
Successful completion.
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWgss (32–bit) |
SUNWgssx (64–bit) |
MT-Level |
Safe |
