Name | Synopsis | Description | Return Values | VALID STATES | Errors | TLI COMPATIBILITY | Attributes | See Also
#include <xti.h> int t_rcvv(int fd, struct t_iovec *iov, unsigned int iovcount, int *flags);
This function receives either normal or expedited data. The argument fd identifies the local transport endpoint through which data will arrive, iov points to an array of buffer address/buffer size pairs (iov_base, iov_len). The t_rcvv() function receives data into the buffers specified by iov0.iov_base, iov1.iov_base, through iov [iovcount-1].iov_base, always filling one buffer before proceeding to the next.
Note that the limit on the total number of bytes available in all buffers passed:
iov(0).iov_len + . . + iov(iovcount-1).iov_len)
may be constrained by implementation limits. If no other constraint applies, it will be limited by INT_MAX. In practice, the availability of memory to an application is likely to impose a lower limit on the amount of data that can be sent or received using scatter/gather functions.
The argument iovcount contains the number of buffers which is limited to T_IOV_MAX, which is an implementation-defined value of at least 16. If the limit is exceeded, the function will fail with TBADDATA.
The argument flags may be set on return from t_rcvv() and specifies optional flags as described below.
By default, t_rcvv() operates in synchronous mode and will wait for data to arrive if none is currently available. However, if O_NONBLOCK is set by means of t_open(3NSL) or fcntl(2), t_rcvv() will execute in asynchronous mode and will fail if no data is available. See TNODATA below.
On return from the call, if T_MORE is set in flags, this indicates that there is more data, and the current transport service data unit (TSDU) or expedited transport service data unit (ETSDU) must be received in multiple t_rcvv() or t_rcv(3NSL) calls. In the asynchronous mode, or under unusual conditions (for example, the arrival of a signal or T_EXDATA event), the T_MORE flag may be set on return from the t_rcvv() call even when the number of bytes received is less than the total size of all the receive buffers. Each t_rcvv() with the T_MORE flag set indicates that another t_rcvv() must follow to get more data for the current TSDU. The end of the TSDU is identified by the return of a t_rcvv() call with the T_MORE flag not set. If the transport provider does not support the concept of a TSDU as indicated in the info argument on return from t_open(3NSL) or t_getinfo(3NSL), the T_MORE flag is not meaningful and should be ignored. If the amount of buffer space passed in iov is greater than zero on the call to t_rcvv(), then t_rcvv() will return 0 only if the end of a TSDU is being returned to the user.
On return, the data is expedited if T_EXPEDITED is set in flags. If T_MORE is also set, it indicates that the number of expedited bytes exceeded nbytes, a signal has interrupted the call, or that an entire ETSDU was not available (only for transport protocols that support fragmentation of ETSDUs). The rest of the ETSDU will be returned by subsequent calls to t_rcvv() which will return with T_EXPEDITED set in flags. The end of the ETSDU is identified by the return of a t_rcvv() call with T_EXPEDITED set and T_MORE cleared. If the entire ETSDU is not available it is possible for normal data fragments to be returned between the initial and final fragments of an ETSDU.
If a signal arrives, t_rcvv() returns, giving the user any data currently available. If no data is available, t_rcvv() returns –1, sets t_errno to TSYSERR and errno to EINTR. If some data is available, t_rcvv() returns the number of bytes received and T_MORE is set in flags.
In synchronous mode, the only way for the user to be notified of the arrival of normal or expedited data is to issue this function or check for the T_DATA or T_EXDATA events using the t_look(3NSL) function. Additionally, the process can arrange to be notified via the EM interface.
On successful completion, t_rcvv() returns the number of bytes received. Otherwise, it returns –1 on failure and t_errno is set to indicate the error.
T_DATAXFER, T_OUTREL.
On failure, t_errno is set to one of the following:
iovcount is greater than T_IOV_MAX.
The specified file descriptor does not refer to a transport endpoint.
An asynchronous event has occurred on this transport endpoint and requires immediate attention.
O_NONBLOCK was set, but no data is currently available from the transport provider.
This function is not supported by the underlying transport provider.
The communications endpoint referenced by fd is not in one of the states in which a call to this function is valid.
This error indicates that a communication problem has been detected between XTI and the transport provider for which there is no other suitable XTI error (t_errno).
A system error has occurred during execution of this function.
In the TLI interface definition, no counterpart of this routine was defined.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
MT Level |
Safe |
fcntl(2), t_getinfo(3NSL), t_look(3NSL), t_open(3NSL), t_rcv(3NSL), t_snd(3NSL), t_sndv(3NSL), attributes(5)
