Name | Synopsis | Description | Return Values | Errors | Attributes | See Also
c99 [ flag... ] file... -lm [ library... ] #include <complex.h> double complex csqrt(double complex z);
float complex csqrtf(float complex z);
long double complex csqrtl(long double complex z);
These functions compute the complex square root of z, with a branch cut along the negative real axis.
These functions return the complex square root value, in the range of the right half-plane (including the imaginary axis).
No errors are defined.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard |
MT-Level |
MT-Safe |
