Name | Synopsis | Parameters | Description | Return Values | Usage | Attributes | See Also
cc [ flag… ] file… -ldat [ library… ]
#include <dat/udat.h>
DAT_RETURN
dat_ep_reset (
IN DAT_EP_HANDLE ep_handle
The dat_ep_reset() function transitions the local Endpoint from a Disconnected to an Unconnected state.
The operation might cause the loss of any completions of previously posted DTOs and RMRs that were not dequeued yet.
The dat_ep_reset() function is valid for both Disconnected and Unconnected states. For Unconnected state, the operation is no-op because the Endpoint is already in an Unconnected state. For an Unconnected state, the preposted Recvs are not affected by the call.
The operation was successful.
ep_handle is invalid.
Parameter in an invalid state. Endpoint is not in the valid state for reset.
If the Consumer wants to ensure that all Completions are dequeued, the Consumer can post DTO or RMR operations as a "marker" that are flushed to recv_evd_handle or request_evd_handle. Now, when the Consumer dequeues the completion of the "marker" from the EVD, it is guaranteed that all previously posted DTO and RMR completions for the Endpoint were dequeued for that EVD. Now, it is safe to reset the Endpoint without losing any completions.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard: uDAPL, 1.1, 1.2 |
MT-Level |
Unsafe |
