Name | Synopsis | Parameters | Description | Return Values | Attributes | See Also
cc [ flag… ] file… -ldat [ library… ]
#include <dat/udat.h>
DAT_RETURN
dat_evd_set_unwaitable(
IN DAT_EVD_HANDLE evd_handle
The dat_evd_set_unwaitable() transitions the Event Dispatcher into an unwaitable state. In this state, calls to dat_evd_wait(3DAT) return synchronously with a DAT_INVALID_STATE error, and threads already blocked in dat_evd_wait() are awakened and return with a DAT_INVALID_STATE error without any further action by the Consumer. The actual state of the Event Dispatcher is accessible through dat_evd_query(3DAT) and is DAT_EVD_UNWAITABLE after the return of this operation.
This call does not affect a CNO associated with this EVD at all. Events arriving on the EVD after it is set unwaitable still trigger the CNO (if appropriate), and can be retrieved with dat_evd_dequeue(3DAT). Because events can arrive normally on the EVD, the EVD might overflow; the Consumer is expected to protect against this possibility.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard: uDAPL, 1.1, 1.2 |
MT-Level |
Safe |
dat_evd_clear_unwaitable(3DAT), dat_evd_dequeue(3DAT), dat_evd_query(3DAT), dat_evd_wait(3DAT), libdat(3LIB), attributes(5)
