Name | Synopsis | Parameters | Description | Return Values | Errors | Attributes | See Also
cc [ flag... ] file... -ldevinfo [ library... ] #include <libdevinfo.h> di_prop_t di_prop_next(di_node_t node, di_prop_t prop);
The di_prop_next() function returns a handle to the next property on the property list. If prop is DI_PROP_NIL, the handle to the first property is returned.
Upon successful completion, di_prop_next() returns a handle. Otherwise DI_PROP_NIL is returned and errno is set to indicate the error.
The di_prop_next() function will fail if:
Invalid argument.
The snapshot does not contain property information.
There are no more properties.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Evolving |
MT-Level |
Safe |
