Name | Synopsis | Description | Return Values | Errors | Attributes | See Also
cc [ flag... ] file... -lm [ library... ] #include <fenv.h> int fegetexceptflag(fexcept_t *flagp, int excepts);
int fesetexceptflag(const fexcept_t *flagp, int excepts);
The fegetexceptflag() function attempts to store an implementation-defined representation of the states of the floating-point status flags indicated by the excepts argument in the object pointed to by the flagp argument.
The fesetexceptflag() function attempts to set the floating-point status flags indicated by the excepts argument to the states stored in the object pointed to by flagp. The value pointed to by flagp will have been set by a previous call to fegetexceptflag() whose second argument represented at least those floating-point exceptions represented by the excepts argument. This function does not raise floating-point exceptions but only sets the state of the flags.
If the representation was successfully stored, fegetexceptflag() returns 0. Otherwise, it returns a non-zero value.
If the excepts argument is 0 or if all the specified exceptions were successfully set, fesetexceptflag() returns 0. Otherwise, it returns a non-zero value.
No errors are defined.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard |
MT-Level |
MT-Safe |
fenv.h(3HEAD), feclearexcept(3M), feraiseexcept(3M), fesetexceptflag(3M), attributes(5), standards(5)
