Name | Synopsis | Description | Return Values | Errors | Attributes | See Also
c99 [ flag... ] file... -lm [ library... ] #include <math.h> int isfinite(real-floating x);
The isfinite() macro determines whether its argument has a finite value (zero, subnormal, or normal, and not infinite or NaN). First, an argument represented in a format wider than its semantic type is converted to its semantic type. Then determination is based on the type of the argument.
The isfinite() macro returns a non-zero value if and only if its argument has a finite value.
No errors are defined.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard |
MT-Level |
MT-Safe |
fpclassify(3M), isinf(3M), isnan(3M), isnormal(3M), math.h(3HEAD), signbit(3M), attributes(5), standards(5)
